My B1 is up and running!
congrats, looks good
just yesterday I decided to build myself a B1 with "Lightspeed" attenuator, yeah
Here is my build thread - lots of pictures and much more information;
http://www.diyaudio.com/forums/pass-labs/181552-b1-preamp-build-thread.html
I see the output RCA side grounded to the PCB but I don't see an input RCA ground reference. Did you miss something or did I?
In similar situations I generally tend to tie all the isolated back panel RCA grnds together and have one (or two if I kept them separate) ties to the PCB.
EDIT: Oh but beautiful job. Neat and well organized. Pretty chassis too!
6L6-
Gotcha. Never saw the blk grd wires.
I saw this picture and didn't see the addition of the two more blacks later in the build.
http://i198.photobucket.com/albums/aa276/aeroplane_album/DSCF3537.jpg
Here is my point-to-point version:
B1 p2p
hi,
I thought i would share a photo of the guts of my p2p b1.
pretty excited about this, i just tested it quickly and seems to be working perfectly.
Now i just need to make a little case for final hookups!
hi,
I only plan on switching between two sources...
I planned on using a toggle. I have some SPDT. I noticed most people are using DPDT switched.
Is there any advantage to switch the ground also?
thanks
DPDT is not for left/right instead of ground for second pole ?
Thanks right, stupid question i dont know what i was thinking. I puts some dpdt on order the other day when i was thinking straight. I was debating on using two before i bought those on using two single poles to get the build done... but forgot temporarily that i need two, i can wait a few days
trying to understand the PS
I've been thinking about the B1 (actually build one as well) and it's power supply.
As I see it, the concept is: take a descent DC-supply. Then follow that by a RC-filter (R1, C1, C2, C3 in the original schematic) to have a really nice supply.
Of course the PS impedance gets larger (R1 is doing that) but that is apparently not a problem because (now follows my thinking )
1. the B1 draws only a little and fairly constant current?
2. there is enough capacity after R1 to provide the current needed (see 1.)?
If this reasoning holds, then increasing R1 gives us a lower corner frequency (less HF-noise), without penalties (the increased PS impedance is not a problem, see 1 and 2).
Please enlighten me, does this reasoning hold, or am I missing something important?
The reason I ask (of course I'd like to understand) is that if this holds, it's very easy to make a symmetrical B1 which is much more in line with the original asymetric circuit by Pass than the interesting circuits proposed by Salas (as mentioned in e.g.: http://www.diyaudio.com/forums/pass-labs/145201-building-symmetrical-psu-b1-buffer.html).
It goes like this:
Start with the (first?) symmetrical schematic by Salas http://www.diyaudio.com/forums/attachments/pass-labs/134693d1243979226-building-symmetrical-psu-b1-buffer-b1psu2xsmall.jpg. Leave out the LM317/LM337 stuff.
Take a decent symmetrical DC-supply. Follow that by an RC-filter, where the R is a preset, and feed the circuit by Salas with it. The DC-offset can then by nulled by virtue of the presets.
See pic:
Please comment on this setup. Is its smart? Is it stupid? Are regulators (LM3x7) better?
Thank you, MArco
It goes like this:
See pic:
Thank you, MArco
- B1 Buffer Preamp
