B1 Buffer Preamp
B1 Buffer Preamp
Old 9th February 2009, 07:42 PM   #1301
rob lenk is offline rob lenk  United States
Default b-1 and attenuator
my two cents- and at least two dollars in paper-someone answer this poor guy's question with a definitive suggestion*
source
preamp
volume control
buffer
amp
best config in my opinion so as not to load down the sources, minimize the noise from the attenuator(gain before) and easiest load with which to drive the amp-this is my 2 cents
now, someone
put me out of my misery
Old 9th February 2009, 07:59 PM   #1302
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
Default Re: b-1 and attenuator
source
preamp
volume control
buffer
amp
now, someone
This would be the ultimate solution. The only problem left, is that unfortunately my preamp doubles up as a headamp, so adding the volume control after the preamp would not work, as the phones outputs would not be attenuated.
http://www.amb.org/audio/beta22/
Old 9th February 2009, 08:04 PM   #1303
R.I.P.
use the headphone amp as a headphone amp.
Feed it with a buffered pot.
Take the output from the buffered pot to your power amp and stop mucking about.
Buffer that pot. How many times do you need to ask and be told?
regards Andrew T.
Old 9th February 2009, 08:05 PM   #1304
rhysh's Avatar
Okay, i will simply buffer the pot and see how it sounds with and without the preamp in the mix. Thanks for the help.
Old 9th February 2009, 09:55 PM   #1305
BFNY is offline BFNY  United States
Anyone looking for a good attenuator solution may be interested in this one also - I see they offer a resistor kit for 20k values.
http://glass-ware.stores.yahoo.net/netcjstat.html
Please don't ask whether to buy carbon or metal film
just kidding
Old 10th February 2009, 05:06 PM   #1306
rhysh's Avatar
Guess whos back .
I have decided to keep my headamp as a headamp, lets ignore that for now.
Back to the situation, im going to build a B1 for my new F5, but i need a small amount of gain to drive the F5 to full power, the output voltage of my dac is only 1.5v.
What would be a good way to do this, keeping it very simple?
Old 10th February 2009, 05:54 PM   #1307
labjr is offline labjr  United States
Originally posted by rhysh
Guess whos back .
Build a B3 ?
Old 10th February 2009, 05:56 PM   #1308
rhysh's Avatar
Originally posted by labjr
Build a B3 ?
Indeed, i forgot about the upcoming B3. Any ideas on when it is supposed to be released?
Old 10th February 2009, 10:55 PM   #1309
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
..., but i need a small amount of gain to drive the F5 to full power, the output voltage of my dac is only 1.5v. What would be a good way to do this, keeping it very simple?
Do you have a BIG room . . . ? Don't worry too much. Be brave
My DAC has also only 1.5V and my speakers have 8ohms 84dB only.
My system goes through DAC >> B1 >> F5 >> 84dB speekers.
Fills up my room space of about 75 cubic metres.
Old 10th February 2009, 10:55 PM   #1310
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
B1 Buffer Preamp
Do you mean for sale, or for schematics?
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
