B1 Buffer Preamp
B1 Buffer Preamp
Old 8th February 2009, 08:54 PM   #1281
BFNY is offline BFNY  United States
Originally posted by rhysh
I can scrap the B1 all together, and just use the volume control but then i will be sending 50K over an interconnect, which is not a good idea...
Says who? This is DIY! Experiment and learn. To get a 50K max. output impedance you would need to use a 100K pot. Why so high? Use a 25K-50K pot then. What is the source impedance?
I made a simple passive attenuator in a small metal box with hardwired in and out connections (no RCA jacks, cables direct wired to the pot with RCA connectors). I made sure the output cables were short (about 20cm or 8") and low capacitance. It works fine and sounds very transparent. Others have made attenuators that mounted directly to the RCA input jacks (no output cables)
http://www.tweakaudio.com/Ultimate%20Attenuators.html
You still need to answer the question - "how much preamp gain do I *really* need for the loudest comfortable listening level?"
This is the whole premise of the B1 article. Try to build the preamp with that much gain, and no more, so that max level is achieved at max. rotation of the volume control. *Not* at 11'oclock, is more common.
Old 8th February 2009, 09:15 PM   #1282
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
A 50K signal over an interconnect is prone to interference with pretty much anything, it will pick up noise Very easliy, especially from AC lines. I have tried this in the past, the same with many others and got an undesirable result.
It may be DIY, but spending $300 on a attenuator project which may not produce desirable results is still a hole in my pocket, DIY or not.
The purpose of the B1 is to convert this into a 1K signal, which is much less prone to interference over an intrerconnect.
This will then be inputted into my preamp.
The purpose of the B1 in my case is to avoid as many interference problems as possible, not to be used as my 'preamp', just in the attenuator.
Old 8th February 2009, 09:20 PM   #1283
the maximum output impedance of an unbuffered attenuator is one quarter of the pot value plus the source output impedance.
50k pot and Rs=1k0 gives Max Zout=[50+1]/4=12k75
10k pot and Rs=1k0 gives Max Zout=2k75
100pF of input and cable capacitance will roll off the treble @ ~125kHz using a 50k pot.
If the power amp is fitted with 1nF RF filter then the treble is rolled off @ ~12kHz.
Unbuffered pots need very careful selection of component values and the listener must accept compromise.
regards Andrew T.
Old 8th February 2009, 09:22 PM   #1284
A 50K signal over an interconnect is prone to interference with pretty much anything, it will pick up noise Very easily, especially from AC lines. I have tried this in the past,
I think this experience is not due to using a 50k passive attenuator, but to some other problem.
regards Andrew T.
Old 8th February 2009, 09:24 PM   #1285
rhysh's Avatar
So do you think i would be fine, using a passive attenuator before my preamp with no buffer, if done properly? We are talking 1 - 2ft of interconnect.
Old 8th February 2009, 09:38 PM   #1286
buffer all sources that have a high output impedance.
regards Andrew T.
Old 8th February 2009, 09:40 PM   #1287
rhysh's Avatar
The output impedance of my DAC (main source) is 3R. If i dont need to use the B1 after my attenuator then i wont bother.
Old 9th February 2009, 02:02 AM   #1288
Sorry, this should read "To get a 50K max. output impedance you would need to use a 200K pot."
This would be way to high for a passive unbuffered attenuator.
Old 9th February 2009, 09:54 AM   #1289
but you attenuator has a high output impedance.
If you want Rs<500r then the maximum pot value would be 2k.
Can your source equipment drive 2k//cable capacitance?
regards Andrew T.
Old 9th February 2009, 10:50 AM   #1290
rhysh's Avatar
My source will drive a normal 50k pot easily. What i am wondering is if i need the b1? Or could i just use a passive attntr.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 09:40 AM
