B1 Buffer Preamp - Page 113 - diyAudio
Old 12th January 2009, 02:14 AM   #1121
Banned
Default JFET Model
OK here is the JFET model from Linear Systems.
If anyone can find an error with it let me know.
File Type: txt jfet model.txt (483 Bytes, 133 views)
Old 12th January 2009, 02:25 AM   #1122
Banned
Hi Homemodder
20kHz looks vey bad indeed. OK there is definitely something wrong
Old 12th January 2009, 12:18 PM   #1123
cHoc is offline cHoc  Netherlands
Send a message via MSN to cHoc
For the B1 could you also use a modified version of the Pearl psu to power it? For as far as i can understand the psu you have to modify/change the resistors around the 2 ZTX450 and the IRF9610, and not only lower the input voltage, but what should the values become to get 18v out of the psu, could anyone help me with that??
Alive and kicking
Old 12th January 2009, 12:56 PM   #1124
Formerly "jh6you". R.I.P.
Babowana's Avatar
Originally posted by cHoc
... what should the values become to get 18v out of the psu ... ??
First off, I recommend D1 of 9.1V Zener, and R12 is to be lowered to 10K from 22K. Then it will give us 18V output.
Old 12th January 2009, 01:32 PM   #1125
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
from where is current for D4 comming ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th January 2009, 01:44 PM   #1126
Babowana's Avatar
From the rail and through an "additional resistor" (it is missing now) to the zener. The size of resistor is to be considered based on the zener current.
Why don't you just add the resistor and correct us at the first place?
Naughty boy . . .
Old 12th January 2009, 01:48 PM   #1127
You're right, Zen mod, i forgot one resistor, it is in this scematic added, and the value of R12 is changed to 10k
Alive and kicking
Old 12th January 2009, 02:05 PM   #1128
What is the gate to source voltage on the FET?
What are the Currents through R8 & R9?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th January 2009, 05:02 PM   #1129
JimT is offline JimT  Canada
thanh1973,
Here is the B1 model I did for LTSpice. It's is simplified a bit from your's, but you should be able to use this to compare differences. Like you I have set the 25k input pot set to half. Simulating the transient, I get the 2nd harmonic at -85dB, 3rd at -120dB and 4th at -150dB and no higher harmonics. The AC Analysis shows that the bandwidth goes up to an F3 of about 3 MHz.
Hopefully you can work out your problem from this.
Jim
Old 12th January 2009, 09:38 PM   #1130
Banned
Thanks you fixed the problem.
I went through each directive starting with the one on top in your circuit, and added an extra directive after each run. It wasn't until .plotwinsize=0 was added that it worked.
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 09:40 AM
Copyright 1999-2017 diyAudio
