Old 9th January 2009, 10:03 PM   #1111
The one and only
Nelson Pass's Avatar
I use the AP1 - the later products are too fancy for me, but we have an
AP2 on one of our benches here.
Old 10th January 2009, 08:32 AM   #1112
Banned
Hi Nelson
It would be nice if you could let us know if the B1 as per the the original design is predominantly 2nd or 3rd order harmonic distortion.
Old 11th January 2009, 01:38 AM   #1113
The one and only
2nd.
Old 11th January 2009, 08:40 PM   #1114
Banned
Thanks Nelson
OK then hopefully I have made a mistake somewhere.
Can someone check the way I have drawn the circuit.
I am a little unsure about the signal ground/return and output ground/return, and the DC power ground/return.
Any help would be most appreciated.
Old 11th January 2009, 09:23 PM   #1115
JimT is online now JimT  Canada
Originally posted by thanh1973
Thanks Nelson
You do not have things setup completely for an FFT with LT Spice. Try adding the following directives.
.tran 0 30m 0.1u
.step param C list .100u .10100u
.option plotwinsize=0
Test at 1000Hz.
If you want to learn more about LT Spice. Try the forum for it on groups.yahoo.com. I am unable to help you further. I just copied the above from an example I found there. It works for me.
Jim
Old 11th January 2009, 10:27 PM   #1116
Just simmed tanh s circuit and indeed it shows that h3 dominates.
Tanh do the sim now at 20Khz and I think youll be even more puzzeled
Old 12th January 2009, 12:16 AM   #1117
The one and only
Whenever spice doesn't match measurement, we look for flaws
in the models first. This would not be the first time that Spice JFET
models have come up a little short.
Old 12th January 2009, 12:30 AM   #1118
udailey is offline udailey  United States
Passive Aggressive
Mr. Pass
I read a post by you that mentioned using the AP1 and some other attenuator after the source and before the amp with a buffer or pre inbetween. I cant for the life of me find it now. You talked about maybe having just a few different resistances to choose from before the buffer/pre and then after it to have, I think, the AP1.
Is this to help 'rectify' any source output/amp input impedance issues or what is the reason?
I think this was with a BOSOZ.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 12th January 2009, 12:36 AM   #1119
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by udailey
Mr. Pass
Uriah
AP1 is measuring gadget , almost capable of computing 42 .
we don't ( we - spoiled kids ) even need to know exactly what's that beast ..........
anyway - I can just imagine using it as attenuator
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 12th January 2009, 12:38 AM   #1120
Passive Aggressive
Ah, I thought it was the Apox-1
Uriah
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
Copyright ©1999-2013 diyAudio
