#1091 |
Banned
I am learning LT Spice at the moment.
So I decided to a spice model of the B1. However looking at the distortion profile, their is mainly 3rd Harmonic distortion with no 2nd Harmonic. This seems a little strange as I didn't see Nelson talk about their being any 3rd Harmonic. Anywy has anyone else modeled this circuit? The way I measured it, was with the following parameters (feel free to correct me on anything): - Voltage input amplitude of +/- 1V (ie 2V p-p) - Volume setting at 12 O'clock using 25k linear pot - Load = 47k resistive load - DC Power = 18V I am a little unsure of the CD Player spec. Is it 2V rms, 2V amplitude, or 2V p-p? Anway have a look at the attachment. PS This is an awesome tool for understanding circuits. |
#1092 |
Banned
Sorry about the attachment. I'll have to shrink the file size down.
#1093 |
I've just finished my cardboard box version of the B1, using NP's DIY board. I have mostly used standard components with the exception of my favorite film caps - obbligato. The 10uF are rather large so it doesn't look as neat as the original does, but who cares about looks! The only pot I had laying around was a 50k alps, but I understand that some prefer lower values. I know that my DAC sounds better with 10k than 50k in my aleph P (SE version with 10k on the input).
So far the sound is impressive, and I am not certain if I want to reconnect my aleph P. Now I need to improve the PSU...I've just done it real simple - a 22000uF after the rectifier brigde. Thank you mr. Pass yet again!
#1094 | |
diyAudio Chief Moderator
CD is about 6V P-P. |
#1095 | |
Are there any B1 boards currently available? Or maybe you made your own? |
#1096 |
Banned
Thanks for that Salas.
Did you use LTSpice to do your FFT measurents, or were they real measurements performed with a distortion analyzer? Anyway here is the attachment. |
#1097 |
Don't forget that the final SOUND depends a lot on those Series Signal capacitors AND the power supply. [don't skimp this].
... jh |
#1098 | |
Upto 2.2Vac = 3.1Vpk = 6.2Vpp |
#1099 | |
#1100 |
Banned
Do you have any idea what I might be doing wrong?
Or is this a common problem with simulators? |
| buffer/preamp? | TheDriver41 | Chip Amps | 2 | 3rd October 2004 08:40 AM |
