Pumpkin preamp - ordered by Steen , official making thread - Page 349 - diyAudio
Old 25th September 2013, 11:59 AM   #3481
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
no problem
decrease R19(a) accordingly - to have around 5mA through
if unsure - put 100R and measure voltage across it
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th September 2013, 03:13 PM   #3482
noSmoking's Avatar
Hi Zen,
Are shunty boards available? or point me to a link to order.
Thanks,
NS
Old 25th September 2013, 04:10 PM   #3483
Zen Mod's Avatar
will send PM
Old 30th September 2013, 09:12 PM   #3484
noSmoking's Avatar
Hi Zen,
Did you send PM ?
NS
Old 30th September 2013, 09:17 PM   #3485
Zen Mod's Avatar
sorry , had stuffed PM box
done some cleaning and I'm gonna write
Old 30th September 2013, 09:26 PM   #3486
noSmoking's Avatar
hi Zen,
No worries take your time,lol. Would you point me to where this DC fix is ? I have built the pumpkin from your layouts,Waiting on a few Parts,lol. and what I'm going to do to power it,lol.
Thanks,
NS
Old 30th September 2013, 09:34 PM   #3487
Zen Mod's Avatar
DC fix is still waiting ...... pretty much finished in LTSpice , but also pretty much not so simple .....
main reason for that issue being on back of list is fact that Pa's ( how dare he !? ) is also having caps ...... everywhere
, however good sounding it is , was just innuendo to next thing ;
that thing , not existing in this Universe , sometimes called as Ultrasymmetry ......
just chill - caps aren't harmful on that sole position
Old 6th October 2013, 02:45 AM   #3488
hi ZM,
i have one pcs talema 2x55v 2x0.73A
can i use for stereo (2channel) pumpkin shunty ?
here the pic:
how to connect properly with the stereo pumpkin.?
thanks.
Aleph 30, Aleph P1.7, Pass F5, B1 Buffer, Aleph J, Pumpkin PreAmp, TDA1541 DAC
http://poshaudio.blogspot.com
Old 6th October 2013, 09:11 AM   #3489
Zen Mod's Avatar
connect black+yellow , to establish center tap for 110V secondary ; confirm proper phasing connecting it to mains and measuring 110V across outer taps (red , orange)
if there is zero V , rotate one secondary
then connect CT to gnd on Shunty input side , outer taps to AC points
make bridges to same points on second Shunty
be sure to make proper ventilation in case , same as proper voltage ratings of caps on input side of Shunty (prior to Q2,Q2a) .... which means 110% x (55 x 1,41)
take care that Q2 , Q2a are heatsinked enough ...... and it's wise to use Irf610/9610 in their position
Old 6th October 2013, 11:51 AM   #3490
my record is:
- it is save giving 110v into this shunty
- 2x0.73A is adequate for 2ch pumpkin+shunty
- using 9610+610 with larger heatsink
- caps prior to Q2 Q2a should be 100v minimum
So basically I am ready to fire on my pumpkin i guest.
Thanks again ZM.
Copyright 1999-2017 diyAudio
