Pumpkin preamp - ordered by Steen , official making thread - Page 346 - diyAudio
Old 26th December 2012, 10:56 AM   #3451
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
I did replied , but can't do again , because I deleted plenty of messages in my box
write here
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 26th December 2012, 11:22 AM   #3452
tonimxp is offline tonimxp  Italy
write here
The question is about C5 1nF Polyester (as project) or 1nF Silver Mica (can it be a upgrade) or without C5 (can the amp be yet stable or not),in this last case how i can check if it is yet in sure zone?
Old 26th December 2012, 11:43 AM   #3453
Zen Mod's Avatar
check for oscillations on output with CRO
if you don't have any , don't use these 1nF
if you need them - put whatever you have in drawer - no need for mica
Old 26th December 2012, 12:13 PM   #3454
Sorry! What is CRO?
I need to use the oscilloscope and signal generator with 100hz 1khz and 10khz signal input?
Old 27th December 2012, 10:40 AM   #3455
COMPARE
the input signal to the output signal using a twin beam or dual trace Cathode Ray Oscilloscope (CRO).
Use a variety of signals, including sine, triangle and square, 10Hz to 50kHz, at a variety of levels.
"Compare" is the really important part of the technique.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th December 2012, 10:54 AM   #3456
Zen Mod's Avatar
Tony
for start - if you're not having enough praxis with CRO , just connect this (attached) across spk terminals,of course - with amp powered on
in silent , then with some light level muzak
if LED's are silent , you're good to go , without those two 1nF caps
Old 27th December 2012, 02:00 PM   #3457
Cathode Ray Oscilloscope (CRO) ...Good to know,thanks Andrew!
About CRO use...i can try to find the power switch and after i can try also to do something more...but Alex i have to tell you ..."you know always something more of Devil" What mind had designed this circuit..almost doubt (for its simplicity) that will work!
Thanks Alex and Andrew!
Old 11th January 2013, 09:15 AM   #3458
Default About shunty heatsink temperature
Hi at all! Please is normal about 70 measured on heatsink of shunty (no load connected and cover open ) ,or i have to add more alluminium sink?
Thank in advance
Antonio
Old 11th January 2013, 09:19 AM   #3459
Zen Mod's Avatar
without load , everything is dissipated on Shunty itself
when you connect load , dissipation will go down ........
so , just relax
Old 11th January 2013, 09:30 AM   #3460
so , just relax
Thanks Alex!
I supposed instead that connecting the load shunty would collapse!
Sorry my mistake
Copyright 1999-2017 diyAudio
