Pumpkin preamp - ordered by Steen , official making thread - Page 345 - diyAudio
Old 21st December 2012, 08:07 PM   #3441
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
believe me - that cap is beneficial only if smallest one is used
ceramic is perfect , but use whatever you have in drawer
as I said - start from 1nF upwards
regarding visit to Italia .......... who knows ...... all roads are heading to Rome , anyway
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 21st December 2012, 08:19 PM   #3442
tonimxp is offline tonimxp  Italy
Ok tomorrow it will be the first thing I do.
I recently live near Milano,so you should consider the idea to visit the next TOP AUDIO nex September.
But this is an other story
Thanks and good night!
Old 21st December 2012, 08:40 PM   #3443
Zen Mod's Avatar
moi despise FiFi fairs
ppl are what's important , when traveling
Old 22nd December 2012, 12:21 PM   #3444
Hello Alex! the stuff may you seem strange, but I tried using a 4.7 nF
and I got a result slightly inferior that obtained with 1uF.
Logically, I carried out an analysis of all the frequency range Hz kHz MHz and found that in the range of kHz 1uF gives better results than 4.7 nF.
So now i decided to leave 1uF.
Now i need a good layout cables assembly.
Please can you give me same good link or informations, if you prefer, also in Private Post.
Old 22nd December 2012, 02:40 PM   #3445
Zen Mod's Avatar
send me info about selector and pot you're using
Old 22nd December 2012, 07:17 PM   #3446
Hi Alex i will use the input selector and volume control showed in pictures attached (red pcb).
I had to change a few things to be able to make it suitable for balanced use . I also have replaced its original pot with a four-way 10K Alps (much better than the original).
In this way i will get the same functionality of the input selector shown in the last picture more the possibility of remote control.
In the third picture the last pcb on the right will serve to keep the outputs to ground for a few seconds (about 10) to avoid bump input to the power amp.
What do you think of this device?
Old 22nd December 2012, 08:33 PM   #3447
Zen Mod's Avatar
having daisy chain of pcbs .......... make it in simplest way , but be avare that you must use one central gnd point (per channel) - either output side of Shunty , or input side of Pumpkin
Old 26th December 2012, 09:00 AM   #3448
Halo ZM,
I'm still have problem with 1 channel. I can't set output offset for - Out (-25V). + Out have no problem (5mV).
I measure VGS for Q5 2.7V, VGS Q6 9.3V.
My supply +/-30V.
Didiet
Old 26th December 2012, 09:32 AM   #3449
Zen Mod's Avatar
send me an email , possibly with few pics of that channel
>sasica5@gmail.com<
Old 26th December 2012, 09:46 AM   #3450
Hi Alex !I sent you in diy private mail a question about C5 aleph 30, please can you reply?
Thanks in advance
Antonio
Copyright 1999-2017 diyAudio
