#3421 |
Hi Tony
![]() easy peasy , for 2SJ109, matching by Idss : source and gate to +9 (max 12V) drain to mA meter red probe mA meter black probe to gnd
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#3422 | |
1° 2sj109 91/92 mA 2° 2sj109 53,5/53,5 mA Please what do you think about different idss betwen 1° and 2° jfet? I also have four 2sj74 bl 6g and i tried with same idss matching method. the results are this: 1° 2sj74 10,10mA 2° 2sj74 10,10mA 3° 2sj74 10,04mA 4° 2sj74 10,07mA Please can you advise me what to use for your Aleph J Babbelfish? Thanks in advance Last edited by tonimxp; 6th December 2012 at 03:19 PM. |
#3423 |
they're fakes
according to 2SJ109 datasheet , there are 3 groups of Idss for exactly same test setup : GR , BL , and V if you made test as I wrote ( see enclosed sketch) , they're fakes without doubts look at 2Sj74 side , presume that Rs is zero , for your case of measuring (full) Idss http://jm.plantefeve.pagesperso-orange.fr/2SJ109.pdf
#3424 | |
#3425 |
see picture above
6 to 12mA
#3426 |
#3427 |
as I said already - in range of 9 to 12V
what you got are probably re-labelled bjt's
#3428 |
#3429 |
So...about my four 2sj74 bl 6g
1° 2sj74 10,10mA 2° 2sj74 10,10mA 3° 2sj74 10,04mA 4° 2sj74 10,07mA Are they ok to use for your Aleph J Babbelfish? And about my post n°3420 of this tread what do you think? For 2sj310 (Q1 and Q2) of Pumpkin i have found those values of Vgs: 180-184-(187-188)-(193-196) mV so i have match as in parenthesis. The current draw is set to 5mA for five minutes test time. I have to ask you your comments for results. Thanks in advance
#3430 | ||
![]() just take care of pinout Quote:
they're good , of course attached pic - view from top (as a bird ....... or Batman )
