Pumpkin preamp - ordered by Steen , official making thread - Page 304 - diyAudio
Old 2nd September 2011, 11:43 PM   #3031
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
try to desolder one of them ( either Q6 or Q8 ) then measure
if bad measurement stays , desolder other one and repeat ;
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 3rd September 2011, 01:14 AM   #3032
Will do
Old 3rd September 2011, 05:52 PM   #3033
I pulled both Q6 and Q8 - the negative rail remains at -19V
Bob
Old 3rd September 2011, 06:31 PM   #3034
Zen Mod's Avatar
now is tricky
it seems that you can exclude possible shortie on pcb , because you measured 10K from neg leg to gnd ;
so - reason must be that some part is conducting excessive current when power is applied .
do this : dismantle heatsink , power up and observe which of those 5 mosfets is excessively heating ; 4 of them must have similar temp , and Q10 must be (almost) cold ;
off course - for start you must be sure that you don't have some wrong resistor there
in any case - fiddle with diode meter here and there ( between pins of each transistor , same as between pins and gnd ) , comparing differences between working and non-working channel , and you'll localize what's wrong
Old 3rd September 2011, 06:38 PM   #3035
thanks Choky - will do
Old 3rd September 2011, 06:49 PM   #3036
The one and only
Nelson Pass's Avatar
We are honored to have you here, Bob.
Old 3rd September 2011, 08:45 PM   #3037
Zen Mod's Avatar
well - if Papa is honored , count that I'm double ......
Old 3rd September 2011, 09:59 PM   #3038
Thank you
I am trying
Old 3rd September 2011, 10:02 PM   #3039
Originally Posted by Zen Mod View Post
now is tricky
I was measuring resistance and found on the board that works
R5=R6 =16k measured across each in circuit and
on the board that doesn't R5=R6 =100k
Old 3rd September 2011, 10:21 PM   #3040
thank you doubly
Copyright 1999-2017 diyAudio
