Pumpkin preamp - ordered by Steen , official making thread - Page 244 - diyAudio
Old 11th October 2008, 11:12 PM   #2431
Stefanoo's Avatar
oh yeah, you know how to go straight to the point hum?
You read the first two lines and skiiiippppeeed the rest.
Give me five!!
Now i can delete my post as it's just occupying useless space as all my answers has been answered by your cookbook
Just keep in mind that as you said....over 2400 post.....not so easy to read them all and informations are just all spreaded around.
the manual is a great idea!
just one last question: do you think that the Jung's regulator works better than shunty?
Stefano
Old 11th October 2008, 11:49 PM   #2432
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
If I'm not mistaking - Jung's reg is series one ?
I mean - I know for several iterations of Jung's reg , but all they are series in topology ;
some ppl prefer series regs , some ppl prefer shunt ones .
I'll not tell that Shunty is better than Jung's reg ....... or vice versa .
I prefer shunt regs , at least in cases where they are economic even in tiniest amount .
anyway - you can't talk about regs , without looking at broader picture - what are the goals and conditions for reg functionality .
edit :
you can still read form start of the thread ....... good laughing material
forzza Rossi !
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th October 2008, 05:21 PM   #2433
spavleski's Avatar
Send a message via Skype™ to spavleski
Shunty is better.
Take a read on Borbely Audio pages http://www.borbelyaudio.com/pics/waagbo2863.pdf
Old 12th October 2008, 06:09 PM   #2434
Stefanoo's Avatar
thanks for pointing this article out.
It looks very similar to this shunty at least it looks to me that it works on the same way, correct?
The Q3,Q2 and surrounding parts are a constant current source which they set the output current.
D3 is the voltage reference R3/15,P1 is the voltage divider that allows output voltage regulator.
Q7/8 is the active load of the dual differential pair Q5 (which a 2SK389 or similar might be useful here i guess to obtain maximum).
D5 should drive the Q11 that will shunt the supply and thus regulating output voltage against R1. (not sure about Q13).
I will read the entire article though.
There are not values nor reference to the parts used here.
Please correct me if i am going to say something wrong:
shunty's type can only supply a precise amount of current set by the CCS and thus can't be, for instance, interchanged on different circuits that have different current demands.
Shunty can only be used on Class A designs.
One last thing: if i am using it on a phono stage that has to source on the plus side 120mA whilst one the - side 80mA, would it still work? or should tweak the CCSs in order to get this asymmetrical current demands?
Speaking of the shunty here and Borbely, if anybody had the chance to try them both, which ones sounds better?
Stefano
Old 12th October 2008, 06:45 PM   #2435
Zen Mod's Avatar
few tips :
- any time , when you are referencing to some schematic ( in so many words and values ) - try to post that schematic ; you can't expect that someone always have time for searching what's in question , and where is that about you are talking
- re-read Cook Book few times ; I just checked - there is page and half, explaining in simple English and technical terms , how Shunty works ... block by block .........
this is Pass forum ...... if nobody else - Papa left so many crumbs and - besides crumbs - so many finished projects , along with technical explanations , so all you need is to invest some energy and collect majority of these pieces , read and learn , build ,read and learn ........
- Shunty vs. Borbely Shunt Reg ..... which is better ?
that's silly question .
better for what ?
Old 12th October 2008, 07:06 PM   #2436
spavleski's Avatar
better for what ?
C,c,c, for Pumpkin, of' course
Old 12th October 2008, 08:14 PM   #2437
Stefanoo's Avatar
few tips :
better for what ?
mmmm....mmmmm.......i read the cookbook different times.
It's clear but there is no analytic analysis and since i am a newbie i get veerryy along with such analysis.
Building is a nice, of course, love it... and i do build... but only after I have completely understood and analyzed the circuit i am trying to build.
I think it is reasonable, isn't it?
I am reading a lot lately and collecting many of the crumbs around....of course I can't collect them all....
I even took the dust off from my electronic 's notebooks from university....I realized i forgot different things....but i am getting back.
Just to see if i understood correctly the circuit though (but i am sure i didn't) and i can't find an answer to this question by reading the cookbook:
assuming Q2/Q3 are ON then there are 140mA sourced to the right side of the shunty by the CCS.
If the load is absorbing, let's say 100mA where does the 40mA difference go?
Accordingly to the simulation i have run on the circuit with Spice, if i put a lets say 120mA current DC generator at the output simulating the load I would get a different Output voltage than the output voltage obtained by using a 100mA current source at the output.
If this is not correct, would anybody be so kind to explain me where my reasoning falls?
With regard to the description i tried to give before...i was just referring to the borbely circuit a member pointed out.
You are right i should have posted it. My apologies
Stefano
Old 12th October 2008, 08:31 PM   #2438
Zen Mod's Avatar
now - you really amuse me with that ......
where else than to Rome ........ just because all roads are going to Rome
spice ....... books .........
these are simple things :
look at differential stage (tip - it works as comparator)
- left side - base of Q5 is fixed to 5V
base of Q4 is comparing voltage on base ( delivered with resistive divider from output) with other side (5V)
base of shunt darlington (Q11) is connected to Q4 collector ( just disregard Q6 cascode ) and it works as .......... say - variable resistor ;
in case that voltage on output is rising , that induce more than 5V potential on Q4 , Q4 conducts more , that induce greater voltage at R12 , that induce that Q11 opens more (decrease apparent resistance) , draws more current , so result is - lowering voltage on output .
easy , isn't it ?
Old 12th October 2008, 09:58 PM   #2439
Stefanoo's Avatar
i am shamed.
It took me awhile!!!!
I have to say that if you never reasoned on this kind of "feedback supply" you don't get it right away.
It's a little bit tricky.
Thanks for the assistance Zen.
Stefano
Old 12th October 2008, 10:16 PM   #2440
Zen Mod's Avatar
Here is one , feedbackless , for you .........
Copyright 1999-2017 diyAudio
