Pumpkin preamp - ordered by Steen , official making thread - Page 112 - diyAudio
Old 19th January 2008, 07:45 AM   #1111
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by hershann
Cookbook says EI transformer is preferred - I supposed due to better noise characteristics and ability to withstand DC etc.
For my Pumpkin the transformer is going to be mounted near the front panel and the audio circuit right at the back (the pot probably actuated via an extension rod).
So should I go for the old EI transformer 250VA, 42VCT x2 (pic 1) or the toroidal transformer 600VA 90VCT (pic 2). They are similar in price - with the EI at $20 and toroidal at $29.5.
BTW how easy is it to shield the EI's stray magnetic field?
her shann
use that EI and place it in separate box ; 600VA donut is really overkill ....... even for Pumpkin
both transformers you show are probably too large ( physically and inducing hum wise) to be in same box with active electronic
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 19th January 2008, 09:18 AM   #1112
Zen Mod's Avatar
Default last last watt F4
you can probably drive it balanced ........ with omitting few last resistors in Pumpie , you can also omit input resistors and big input caps on this last last watt F4 .......
or I'm missing something ....... as usual .........
Old 19th January 2008, 09:40 AM   #1113
cviller is offline cviller  Canada
cviller's Avatar
Default last last F4
Interesting drawing, but I think you'll still need something for balanced to single ended conversion, because the input you have shown on your last F4 must have identical phased inputs, only with 8V dc difference...
I bet pumpkin will kill those tl431 very fast!
Old 19th January 2008, 10:58 AM   #1114
Zen Mod's Avatar
Default Re: last last F4
dunno ......... I'm still fuzzy - flue ....... dumb ( that last like always )
I'll think more maybe tomorrow .........
Old 19th January 2008, 12:06 PM   #1115
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
My Shunty trannie pickings.
Single 44Vac secondary, means 2 trannies per channel, 4 total.
Split-bobbin type, primary winding in the bottom section and the secondary on top, metal shielding.
NOS Cheapo. (of course)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 19th January 2008, 12:25 PM   #1116
mpmarino's Avatar
That's a lot of wires! Too complicated, no?
Crazy Yankee.
Old 19th January 2008, 12:35 PM   #1117
Formerly "jh6you". R.I.P.
Babowana's Avatar
Default Re: last last watt F4
When you are out of flue and find yourself fine, I hope you will
look back into the last last circuit . . .
Papa feeds F4 with the one phase input to the all FETs
Old 19th January 2008, 01:09 PM   #1118
Originally posted by mpmarino
a lot of wires
4 times 4 is 16 wires.
2 transformers with 2*115Vac primaries and dual secondaries count up to....16 wires.
These are so small that they'll fit in a 3 1/2 " high case.
(burp, same height my Aleph-J cases will have)
Old 19th January 2008, 01:44 PM   #1119
mpmarino's Avatar
Ya know,
I had a hard time deciding whether or not to put the trafo in the pre case. In the end I decided to chicken out and keep it outside. I've been having cr@p luck with noise lately - I think it's the 106dB horns' fault.
That is, when I can get back to work on this stuff - I had to put the pumpy on a high shelf
edit: Aleph J? is that anything like the Babelfish?
Crazy Yankee.
Old 19th January 2008, 01:52 PM   #1120
Zen Mod's Avatar
dunno ............. will it drive F4 ?
Copyright ©1999-2017 diyAudio
