#11 |
Nice...
I have 4 pcs. 2SK147 matched and there might fit well here... I will use a lower power supply (20V secondary) and only on pair of output devices, giving a very simply amplifier. 10W will be enough.... |
#12 |
4 pcs of 2SK147 will work fine, as in my case, with transconductance at about 80mA/V.
This device is really hard to find now and 2SK170 only has half of the transconductance. At 20V power supply, are you sure you can get 10W? I have not done any calculation but at 40V power supply I believe I am getting 10W. |
#13 |
You can use 2SK369 which has double the transconductance of 2SK170. Widely available in BL grade, which fits the application.
Patrick |
#14 | |
#15 | |
| FS: Philips CD931 with internal TDA1541A DAC & JFET STAGE | cartman | Swap Meet | 1 | 9th April 2011 06:49 AM |
| I/V stage with a common gate Jfet? | Bricolo | Digital Line Level | 18 | 2nd May 2009 06:17 PM |
| JFET D1 I/V stage for ESS Sabre DAC | khundude | Pass Labs | 7 | 17th June 2008 08:38 PM |
| Power Supply for jfet line Stage | maxpou | Solid State | 23 | 13th June 2008 12:29 AM |
| A chopped Mini-A with Jfet input stage | Fuling | Pass Labs | 12 | 15th November 2006 07:45 PM |
