Old 4th June 2008, 10:16 PM   #11
luvdunhill's Avatar
Originally posted by agent.5
But I still managed to carry two 1.5KV transformers home using the city bus. Many breaks required.
just curious, what is their diameter? I'm working on a case and if it is large enough to handle one of these, I'll consider it a "upgrade proof" design.
Old 4th June 2008, 10:23 PM   #12
agent.5 is offline agent.5  United States
This is what I got,
Powertronix
25v-0-25v 20A
30v-0-30v 0.1A
7-3/16" diameter
2 -3/8" height
>20 lbs each.
I purposely did not pick those Piltron as they are heavier. I think they may be another 1/2" wider in diameter.
Old 4th June 2008, 10:55 PM   #13
defect9 is offline defect9  Ireland
defect9's Avatar
and here i was thinking that a pair of 300VA toroids with dual 18v secondaries would be future proof enough for me... wow.
-Jared
Old 5th June 2008, 12:11 AM   #14
Stefanoo's Avatar
Originally posted by Nelson Pass
Some are older types, some don't pass the stethoscope test.
How old?
What is the stethoscope test?
Do you test the transformers with a stethoscope to evaluate the noise performance?
A true low noise shouldn't be audible by a doctor stethoscope's inspection?
Usually transformers that passed the actual test are better sounding than those ones who haven't passed it indeed?
I sincerely don't care about weight and i rather prefer a heavier transformers than a lighter which gives me the idea of something not as consistent.
I already seen a proper casing for these transformers and stuff.
If you wanna know some dimensions of a similar Plitron's beast, take a look at here
http://www.plitron.com/shopping/specs/739500.pdf
What is the difference from the previous models and the newer models?
What makes me wonder is that from an expensive product as a low noise plitron transformer you still need to select them for an even lower noise level.
Is this so relevant?
Would it be possible to purchase a couple of your newer model plitron transformers?
Or do you think that for better performance i would have to order one from the factory?
But if i haven't misanderstood even ordering one from them i can get a transformer that wouldn't pass the stethoscope test, right?
huummm!!
Stefano
Old 5th June 2008, 10:30 AM   #15
Stefanoo's Avatar
emmm....just re-read the post and it seems i am refering to Nelson when i pointed the link for some dimensions eheheh.....i was giving it to luvdunhill that was wondering about sizes
Stefano
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
FS Plitron 3035-SE output transformer Ben Reginato Swap Meet 0 21st March 2006 09:42 AM
plitron 6c33c output transformers for TRADE contaxchen Swap Meet 4 21st July 2005 12:16 AM
Page generated in 0.07957 seconds (76.74% PHP - 23.26% MySQL) with 10 queries
