#11 |
I have the impression that something is really wrong; either you accidentially shorted the secondaries or the toroid may have a tiny internal short.
100VA are no problem; indeed regulation is better with larger toroids, so don't worry at all about that. I would not use a larger fuse! Nor a soft start circuit! You have nothing connected to the secondaries, so that's the lightest load the psu will ever be. Find your fault first before going further. My advice is check your toroid with a multimeter. Check resistance of primary and secondary windings. How come you measure 34V without rectifying? Are you using a true RMS-multimeter? Or are these peak values? Don't forget DC-voltage will be 1.42*RMS value. Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#12 |
I'm inclined to agree, Hannes. I certainly will not use a larger fuse. My DVM is not true RMS, in fact, it's about as cheap as you can get. But, I have access to good meters at work, so I'll check it out there.
But, in the interest of time, I think I will go ahead and order another, smaller, transformer. I appreciate the help! |
#13 | ||
Lightning In A Bottle
Without any load on the the toroid and with a fuse on one line of the primaries, and like you said..."simply use only one of the primary windings". If the fuse does not pop measure your secondary(ies). If the measurement is as advertised, unplug primaries and parallel second set of primaries. Plug paralleled primaries...if the fuse pops, unplug and reverse 2nd set of primaries. If the fuse does not pop go ahead and measure the secondaries and it should be the same as the first set of measurements. If the fuse still pops you have shorted primary windings...disconnect and buy a new transformer allan
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
| Keep Blowing Fuses | Whiting | Tubes / Valves | 9 | 11th September 2008 09:44 PM |
| Car Amp help? Fuses blowing... | Tolo | Car Audio | 1 | 3rd December 2007 01:42 PM |
| Why are these fuses blowing | Darin P-B | Solid State | 41 | 30th May 2005 10:56 PM |
| The Fuses Just Keep Blowing | raffir | Chip Amps | 19 | 22nd June 2003 03:49 AM |
| Why does my PSU KEEP blowing fuses?! | Rarkov | Parts | 29 | 17th October 2002 03:35 AM |
| Page generated in 0.06843 seconds (74.38% PHP - 25.62% MySQL) with 10 queries |
