I have a Pearl that I'm assembling and I'm running into what is probably a common noob problem. I have the primary wires connected (directly) to the IEC power module on my PS enclosure with the secondary wires not connected to anything. About every second or third time I switch the power switch on it blows the 1A fast acting fuse.
When it does not blow the fuse, the secondary voltages seem OK (about 34 volts).
I realized that my transformer puts out 100 VA. The one in the Pearl article puts out 30 VA. Is this my problem? If so, what should / can I do about it?
Thanks.
Thanks.
I would not sweat it, you may want to use a slow blow fuse anyway. My transformer is about the same size as yours (overkill but the only one from AnTek had at that voltage). When I turn off my power supply the power Led will stay lit for a minute, I don't flick the power off and on right away cause I know it will blow the fuse ( to lazy to put a bleeder resister in).
adding bleeder resistors will not help the fuse blowing problem.
The usual fuse rating for a motor or transformer is approximately three times the rated maximum supply current.
For a 100VA transformer this is 3*100VA/110Vac~=T3A.
You may get by with less than this.
If you want to close rate the fuse then consider adding a soft start using either a Power resistor or Power thermistor. The resistor must have a delayed bypass and the thermistor version all benefits from the added bypass.
OK, so I may have a primary winding which is out of polarity and I should have bought a smaller transformer. I may want some thermistors (need to read up on the F1 service manual...) and some bleeders.
To start, and until I can get parts in, could I simply use only one of the primary windings? Wouldn't that cut my current in half and eliminate the polarity mismatch?
And here I thought the PS would be the easy part to debug!
if a dual primary is wired in parallel for 110/120Vac and one of the windings is out of phase with the other then the transformer acts as resistance of just a few ohms across the mains voltage. Bang goes the fuse every time (just as Nelson said).
If it only blows occasionally then the windings must be correctly wired, but the start up current is too high for the size of fuse.
Either fit a bigger fuse and take the risk that goes with that or reduce the start up current using a soft start circuit.
I have the impression that something is really wrong; either you accidentially shorted the secondaries or the toroid may have a tiny internal short.
100VA are no problem; indeed regulation is better with larger toroids, so don't worry at all about that.
I would not use a larger fuse! Nor a soft start circuit!
You have nothing connected to the secondaries, so that's the lightest load the psu will ever be. Find your fault first before going further.
My advice is check your toroid with a multimeter. Check resistance of primary and secondary windings.
How come you measure 34V without rectifying? Are you using a true RMS-multimeter? Or are these peak values? Don't forget DC-voltage will be 1.42*RMS value.
Have fun, Hannes
Have fun, Hannes
I'm inclined to agree, Hannes. I certainly will not use a larger fuse. My DVM is not true RMS, in fact, it's about as cheap as you can get. But, I have access to good meters at work, so I'll check it out there.
But, in the interest of time, I think I will go ahead and order another, smaller, transformer.
I appreciate the help!
Nelson Pass said:Likely the polarity of one of your primary windings is reversed. That
will do it every time.
Paul Ebert said:....
To start, and until I can get parts in, could I simply use only one of the primary windings? ...
Have you tried the above like you described? Here's how you troubleshoot it to make sure it's just polarity reversal and not shorted toroid...
Without any load on the the toroid and with a fuse on one line of the primaries, and like you said..."simply use only one of the primary windings". If the fuse does not pop measure your secondary(ies). If the measurement is as advertised, unplug primaries and parallel second set of primaries. Plug paralleled primaries...if the fuse pops, unplug and reverse 2nd set of primaries. If the fuse does not pop go ahead and measure the secondaries and it should be the same as the first set of measurements. If the fuse still pops you have shorted primary windings...disconnect and buy a new transformer
allan
- Pearl PS blowing fuses
