in the end i was able to get work the Zen v9
the toroid is a 300VA and get off-load voltage of 36volt. i used a 47000uf filterbank. on the drain of Q4 i get "only" 47volt... and now... on the drain of Q3 i get 42volt. is it normal that i am unable to get 21 (one-half of the voltage of Q3) but i can't do this because the lower voltage i can get on the drain of Q2 is 24volt. the p1 is work correctly and is a 25k one. the only part that is different from mr.pass original design is the Bc639 in place of ztx450. what can i check ? is it normal ? thanks guys, you are my hope |
#2 |
The one and only
Try a little lower value for R14, the 33K resistor.
#3 |
30k is a good value ? the shops has only E24 value....
#4 |
it works great. i used a 22k resistor and now is ok...
the last think... is it normal the big voltage drop between Q4 and Q3 ? in the original design is excpected to be 2 volt, in my case the are about 6 volt... thanks |
#5 |
Another little question about voltage and amperage:
the toroid emits a noise like a fuzz (very low...) but a fuzz on a 300VA toroid isn't espected to be. i measured each current and here you are the values: on the primary of toroid : 0.53 A on the secondary of toroid : 3.15 A on the output of the bridge : 3.51 A on the ouput of the filter : 2.1 A voltages are : on the secondary of toroid : 34V on the output of filter : 45V Q4 (drain) : 45V Q3 (drain) : 40V Q2 (drain) : 20V (adjusted by P1). the test filter bank is formed by : 2x 10000uf 160V --> 0.25 ohm 25W resistor (parallel of 4x 1ohm) --> 1x10000uf 160V -> 2 x 6800uf 100V. NO FILTER on the AC line and a 2.2K 3W resistors is putted between + and GND as bleeder. the toroid is 300VA then : 300VA / 34V = 8.8A (twice the current that really flows in my case). is the toroid broken ? is it normal that fuzz with these "high" currents ? What can i check for you ? thanks a lot ! |
#6 | |
The fuzz of the toroid , in my experience , depends of other AC loads connected in the line at the same time, such soldering iron ( some types ) and other inductive loads . When I use the CL60 thermistors at the imput of them , toroids seems to fuzz less . Perhaps also the bridge diodes arrangement makes some difference . For instance , the original First Watt PS arrangement for the F3 fuzzed lot less in my case . If better toroid quality makes differences .... I dont know . |
| ESL voltages | Fanuc | Planars & Exotics | 5 | 11th February 2006 08:36 PM |
| Floating voltages | eeka chu | Solid State | 12 | 29th January 2004 04:57 PM |
| Floating voltages | eeka chu | Parts | 2 | 27th January 2004 10:10 AM |
| PSU cap voltages | lawbadman | Solid State | 4 | 3rd January 2004 01:37 PM |
| TV set voltages? | setmenu | Everything Else | 10 | 20th March 2003 02:36 AM |
| Page generated in 0.08683 seconds (78.91% PHP - 21.09% MySQL) with 10 queries |
