Old 13th March 2003, 12:55 AM   #1
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Default Question about the radiator
I have six radiators(170mm X 145mm X 50mm) , plan to make ZEN V4 I wonder whether it is enough or not?
Old 13th March 2003, 09:20 PM   #2
From my experience, you need about 65cm^2 per watt of dissipation. The amplifier dissipates about 90W per channel, so I think that your six is just about right for one channel. Oh, that is with a separate heatsink for the transistor in the voltage regulator. Seven for each channel would be ideal. You could build one channel with the six you have, but it would be a bit warm. No disaster.
I hope you can find six or seven more!
We usully call them "heatsinks," but you are right, they are indeed radiators.
Good luck!
Vince Harris
Old 13th March 2003, 09:37 PM   #3
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Hmm - those heatsinks looks very same as the ones I used for my Zen v4 prototype ... They didn't seem - but they were OK (when bias was set to arround 1.3 A) - BUT - you must allow air-flow from both sides!
Well - OK - mine are 100x115x65; so they are quite smaller - well later I've found a datasheet for them - each one has K/W koefficient arround 0,7K/W ..
passive radiator question krikus050 Multi-Way 7 5th October 2008 06:53 PM
Passive radiator Chris8sirhC Subwoofers 4 5th August 2008 05:49 PM
Newb spkr/passive radiator rebuild question FSULongM Multi-Way 3 17th January 2006 06:53 AM
Peerless 10" XLS finished- passive radiator question tktran Subwoofers 2 30th May 2005 12:01 AM
Subwoofer and Passive Radiator question... WolfmanX Subwoofers 0 19th November 2002 01:10 PM
Page generated in 0.06958 seconds (74.94% PHP - 25.06% MySQL) with 11 queries
