Old 25th May 2008, 01:02 PM   #21
JBL4435 is offline JBL4435  Germany
Good Amp input
Old 25th May 2008, 01:04 PM   #22
Good Amp PS
Old 25th May 2008, 01:08 PM   #23
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
what is bias in these amps ?
are these chokes air wound ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 25th May 2008, 01:27 PM   #24
app. 18.5 V
app. 4.3 Amps bias
Power supply ripple
good Amp, app24 mV peak to peak
bad Amp, app24 mV peak to peak
These chokes are ferrite core bobbin types rated for >15 Amps
They reach app. 70°C
Old 25th May 2008, 04:48 PM   #25
Default Solution
Maybe this helps not only me but all plagued by hum.
It comes from the transformer! Turn the transformer till the amp is quiet.
When the transormer outlets are on 3, 6, 9, 12 o'clock there is hum.
If they are at 1:30, 4:30, 7:30 or 10:30 there is no hum.
Mine where at 12. Seems to be in realtion to the chassis walls.
Try it!
Old 25th May 2008, 06:11 PM   #26
Zen Mod's Avatar
Default Re: Solution
Try it!
certainly worth trying ;
Papa wrote (few ?) times about same issue
Old 25th May 2008, 10:28 PM   #27
macka's Avatar
Guido,
Do not dispair,
I also have had that problem with another product......
Please bare in mind its still being picked up by the amps and some thing is acting as a antanna.
Check that all aluminium panels are at ground potential.
What is the bottom panel made of?
Ground the input stage earth with 3 ohms to chassis ground.(A must do)
Also, try to shield all the input wiring. I would suggest splicing the coupling caps into external the cable if it helps reduce the hum.
Re-route those wiring coming over the transformer. That is full of noise! They should be all twisted in a spiral together and be attached to the chassis.
If all that fails put a 4-6 mm plate steel partition across the chassis in front of the board isolating it from the rest of the interior
I just had a look at my X Aleph, no hum no matter what I do.
Ian
Strange XO behaviour tinitus Multi-Way 10 7th March 2009 02:50 AM
Cathode FB P.P. Strange behaviour. Larry Lomax Tubes / Valves 3 5th May 2008 08:36 AM
Strange 45 behaviour - help hal3101 Tubes / Valves 2 9th November 2007 08:38 AM
Strange vol. pot behaviour ?! Cradle22 Solid State 11 28th January 2004 08:08 PM
Strange amp behaviour.... 5th element Solid State 13 6th July 2003 04:54 PM
Page generated in 0.09176 seconds (75.76% PHP - 24.24% MySQL) with 11 queries
