Forté Audio Model 3: caps and schematics? - Page 2 - diyAudio
Old 29th May 2008, 09:02 PM   #11
st2_998 is offline st2_998  Italy
st2_998's Avatar
Well, I don't really think of something possibily blowing up.
I don't have a variac but I can disconnect the channel fuses isolating the PS and checking voltages before reconnecting the audio circuitry.
Thanks.
Luca
Old 28th January 2009, 07:12 PM   #12
Default Forte Model 3 cap upgrade/conversion
Hi all. I am the proud owner of one of Mr. Pass' fantastic designs, (albeit one of his lesser works). The Model 3 is a (Threshold) 200 wpc (8 ohms) Class A/B design with a fairly high Class A bias, and the case and internals are virtually identical to the Model 1A, a 50 wpc Pure Class A amp. My amp is a low-hours unit, and sounds fantastic. Because it is an older model though, I am considering upgrading the caps. I am also considering converting the amp to the Pure Class A 50 wpc configuration. I understand this is a fairly easy process, as the internals are the same. Any suggestions on capacitor upgrades or the Class A conversion? Mr. Pass?? Thanks. -David
Old 29th January 2009, 01:59 AM   #13
The one and only
Nelson Pass's Avatar
IIRC, you can tap the transformer at 240V and just crank up the bias.
Old 29th January 2009, 02:08 AM   #14
The one and only
Here's a schematic.
Old 29th January 2009, 01:24 PM   #15
Thank you Mr. Pass! One other question: The stock power cord is a smallish two-prong unit. This may seem like a "no-brainer", but do you recommend upgrading to an audiophile-grade cord with ground? If so, would you think it better to add an IEC male socket to the rear panel (to enable "cord experimentation", or pass a fixed cord through the rear panel & enlarge the port & grommet? Thanks again! -David
Old 30th January 2009, 07:36 PM   #16
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by Nelson Pass
schematic
Cool location of the thermal breaker.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 30th January 2009, 08:34 PM   #17
The one and only
Default Re: Forte Model 3 cap upgrade/conversion
The IEC socket would be preferred. You will have to deal with the
grounding if you use a cord with AC earth - the chassis must be
hard wired to the AC earth connection. A connection from the analog
ground to the chassis can then be made directly, or through a big
diode bridge and/or power thermistor which can provide some low
level isolation against ground loops but conduction against a primary
to secondary type fault.
Old 31st January 2009, 09:18 AM   #18
st2_998's Avatar
No advice for recapping then? (see also old posts at top of thread)
Thanks for sharing your knowledge, Mr. Pass.
Luca
Old 31st January 2009, 11:34 PM   #19
The one and only
I advise you to re-cap at your convenience.
Old 2nd June 2011, 08:11 PM   #20
Send a message via AIM to SL10User Send a message via MSN to SL10User Send a message via Yahoo to SL10User
Default Capacitors in Model 3
one question:
the two capacitors for each voltage in the Model 3 are wired in serial. As I learned some time ago the total capacity then is half the capacity of one capacitor (24 mF turns into 12 mF).
Isn't that a drawback? Why are they not paralleled?
Cheers
Forte' audio model two preamplifier saperusa Pass Labs 17 30th May 2017 06:28 PM
Anyone got schematics for the Cambridge Audio model P40? andjur78 Solid State 17 24th February 2017 06:29 AM
Forte Audio Model ONE WolfgangL Pass Labs 1 23rd February 2011 01:04 PM
Forte Model 4a Heiney9 Pass Labs 3 16th July 2007 08:44 PM
Forte Audio Model 3 Power Amp. celonaf Pass Labs 3 25th November 2004 06:35 AM
Copyright ©1999-2017 diyAudio
