Old 3rd June 2011, 12:17 AM   #21
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The P is guru of logistics also.
=> Serial or parallel
Old 13th June 2011, 07:31 AM   #22
wannabeaudiophile is offline wannabeaudiophile  United States
Originally Posted by P. Lambda View Post
Looks right. I saw some old usenet postings that led me to
turned my Forte 3 into a 1 -- I only had to reroute the wires.
Now completely class A -- sounds better.
Lambda, I know this is an old post. I just acquired a Forte Model 3 amp and want to convert it into class a. Wonder if you can give us instructions and maybe photos of the class a conversion of your Forte amp. Thanks.
Old 15th June 2011, 02:42 AM   #23
P. Lambda is offline P. Lambda  United States
It's been awhile. The Forte 3 had the
two transformer secondaries in series and the two channels shared
the single DC supply.
I unscrewed and reconfigured the leads to give
two DC power supplies -- one for each channel with
each one using its own secondary.
I didn't have to replace or buy anything -- just replug what was there.
Be careful when you bring the amp up because the bias pots
are very sensitive. I blew a couple of rail fuses.
Old 15th June 2011, 02:46 AM   #24
I meant to say that the two channels shared the same secondary, but
they each had their own pair of capacitors.
Old 17th June 2011, 12:20 AM   #25
Is your amp still running 200watts/channel or 50watts/channel? Thanks again.
Old 17th June 2011, 05:19 AM   #26
After the change, the amp ran at 50W output, but I later
replaced the pcbs with a diy aleph 5 circuit.
Old 17th June 2011, 08:36 AM   #27
Blasphemy. Repent, sinner !
Old 18th June 2011, 06:22 AM   #28
Got my Forte model 3 today. Been running it for 3 hours now. Are the heatsinks suppose to be cool? I also noticed that the highs and mids aren't smooth?
Old 19th June 2011, 05:27 AM   #29
Buying a Forte 1 or 3 with cold heatsinks
is a common problem. Mine had that too.
In most cases, you just need to increase the bias
by turning the pot on each circuit board.
You have to be very careful because they are VERY sensitive.
As I mentioned, I blew out a couple of rail fuses before I got it right. Increase the bias until the heatsinks can only be touched a few seconds. There is a post on this forum, on how to use a voltmeter to get the
right bias on this amp.
Also, make sure that the thermistors are in contact with the heatsink.
Mine had one loose which negatively affected the sound.
Old 19th June 2011, 05:46 AM   #30
MOER is offline MOER  United States
Default Forte and power cord
If you want to change the power cord to one of these "black Magic" types what in heaven's name are you going to do with the cables running from your wall socket to the breaker board in your home and then the larger challenge is how to change the cables from your breaker board to the transformer which feeds your home (and others). Then you need to consider changing the cables from the local transformer to the main power lines. Oh and I forgot what about changing the primary wire (just plain old copper wire) in the power transformer?
Do you honestly believe that changing 1 metre or so of power cable will change the sound in your speakers where you have many kilometres/miles of dumb copper wire between your amplifier and the power source?
It is the same as putting one great tire on your car and leaving the other three as junk and expect that now your car will handle like a race car.
Electrons are dumb!
Forte' audio model two preamplifier saperusa Pass Labs 18 2nd April 2018 05:21 PM
Anyone got schematics for the Cambridge Audio model P40? andjur78 Solid State 17 24th February 2017 06:29 AM
Forte Audio Model ONE WolfgangL Pass Labs 1 23rd February 2011 01:04 PM
Forte Model 4a Heiney9 Pass Labs 3 16th July 2007 08:44 PM
Forte Audio Model 3 Power Amp. celonaf Pass Labs 3 25th November 2004 06:35 AM
