Aleph 5 (4 x  IRFP240 per channel)
Old 21st May 2008, 06:37 PM   #1
peter7 is offline peter7  Hong Kong
Default Aleph 5 (4 x IRFP240 per channel)
Hello, I want to build Aleph 5 have 4 x IRFP240 per 1 channel (original is 6 x IRFP240), is it possible? is it need to change some?
Old 22nd May 2008, 02:59 AM   #2
Stones is offline Stones  United States
Stones's Avatar
ok you have had 61 reads and no response, this happens when you ask a question that a little searching will answer.
The original Aleph 5 had 6 fets, if you lower this to 4 with no other changes you will have one third less current available.
You can find an excel sheet done by wuffwaff that will help you calculate the effects.
I don't feel like you know what voltage or current you need so I can't concisely help you.
Old 22nd May 2008, 06:29 PM   #3
Hello Stones, thanks for your reply, I use +- 35VDC which is original circuit ,some people told me just change the R64-66 & R40-42 from 1 ohm to 0.7 ohm for 4 fets ,is it correct??
Old 23rd May 2008, 01:01 AM   #4
Stones's Avatar
There are other ways to change the current but it sounds about right, you know the fets will run hotter than god intended in the original design. Would it not be better to build it with lower rails (Aleph 3, or better yet build the AlephJ) what load are you running into?
Old 26th May 2008, 07:32 PM   #5
karajak is offline karajak  Greece
hi ! i want to use 8 240s instead of 6 for aleph5 with 31,5 V. The use of 1,5ohm resistors is the action correct?
Old 26th May 2008, 07:54 PM   #6
Blues is offline Blues  United States
Blues's Avatar
With lower supply voltages and more output devices you can keep 1R power resistors for a better performance in low impedance loads. 2A total bias.
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 26th May 2008, 08:30 PM   #7
thanks for the reply.i will keep the 1om resistors.i wonder if this way the temperature per fet is lower?
Aleph 5 (4 x  IRFP240 per channel)Hide this!Advertise here!
Aleph 5: IRFP240 vs IRFP240A or ??? RussB Pass Labs 0 9th October 2006 06:57 PM
Matced IRFP240`s & Aleph-x rev 1.0 PCBs skaara Swap Meet 12 21st August 2006 06:22 PM
SFH9240 instead IRFP240-aleph-x freakyone Pass Labs 10 30th June 2006 03:14 AM
matched irfp240 aleph 2 MikeZ Pass Labs 0 17th January 2003 09:42 PM
Copyright ©1999-2017 diyAudio
