another local NS10 & Shiny
Old 27th October 2008, 07:11 PM   #41
massimo is offline massimo  Italy
Hi Choky!
Maybe a silly question (but pls no silly answer!) or maybe already asked you too many times, but where can we buy the pcbs as seen in post 32?
I'm mainly interested on a couple of the shunt reg pcb.
Old 27th October 2008, 07:44 PM   #42
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally posted by massimo
Hi Choky!
well - I'm not responsible for pcbs ( I am just for back of napkin sketch of circ ) , but you can ask bogdan_borko for that ;
dunno - seems that zei is working on split version ( Shinyy , in my hysteric nomenclature ) ; you can look in digital , Papa's D1 pcbs thread .....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 28th October 2008, 07:23 PM   #43
GuidoR is offline GuidoR  Italy
GuidoR's Avatar
Hi all,
In case somebody agrees, here's the artwork of the Shinyy ( not yet tested!!!).
Guido
Massimo, in the next days I'll etch my sample: do you need one, too?
e-mail me
Guido
Old 28th October 2008, 07:27 PM   #44
GuidoR's Avatar
The files (Express PCB)
Old 28th October 2008, 10:05 PM   #45
Zen Mod's Avatar
Originally posted by GuidoR
Hi all,
Guido
e-mail me
Guido
btw - express pcb file is Isnogood for any other proggie
Old 29th October 2008, 01:37 AM   #46
Hi all,
Guido
e-mail me
Guido
Thank you for your offer, Guido.
No, I need a dual mono p.s. (2 x Shiny), not a dual p.s. (Shinyy).
I'm now working on my own pcb.
Old 30th November 2009, 09:55 PM   #47
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Alors,
I built a shunty for the B1 but it won't turn on.
I hooked the circuit up to 42VDC and it draws like 60mA.
The section with the LM317s seems fine and puts out 27V.
But the voltage at the gate of the IRF510 won't rise above 5.7V. I replaced the FET. The one pulled from the circuit looks fine so it's likely that this wasn't the problem.
Could the BC546B be the cause?
(the darlington in the sim is not the actual one, it's a BDX53C)
The second channel I build won't turn on either, so I must have made the same mistake twice, hopefully.
Maybe someone can give me a hint.
Thanks guys!
Gravity - Making the G since 13.7 billion B.C.
Old 30th November 2009, 11:41 PM   #48
Zen Mod's Avatar
Originally Posted by Rodeodave View Post
Alors,
Thanks guys!
circuit can't draw more than 0V65/R9
disconnect everything after CCS , then connect output of CCS via mA-meter to gnd and check current ;
on schematic everything looks good to me ; culprit must be somewhere in your actual implementation ;
did you checked twice orientation of parts , especially BDX ?
it's
Old 1st December 2009, 09:41 PM   #49
hates ground loops
Rodeodave's Avatar
Thanks a lot, choky, I think I'm on to something. I disconnected everything after the CSS and checked what current it would push through a DMM to ground. It's around 50mA, just as expected. Unloaded it puts out some 25V, haven't checked the voltage with a load, but will do tomorrow.
So the error must be in the shunt-regulator part. I'll check all polarities and keep you posted. Hope I see them LEDs actually emit someday.
Thanks a lot!
Old 1st December 2009, 11:30 PM   #50
Zen Mod's Avatar
Mighty ZM .......... here , to Serve and Protect !!
another local NS10 & ShinyHide this!Advertise here!
My Take on Threshold NS10 Russ White Pass Labs 583 23rd May 2012 06:05 AM
lead-free solder: shiny when liquid but suddenly it turned dull when it solidified jarthel Parts 3 5th August 2006 07:52 PM
Threshold NS10 ponger Pass Labs 4 12th November 2005 12:29 PM
Copyright ©1999-2017 diyAudio
