Old 10th May 2008, 11:52 AM   #1
Skorpio is offline Skorpio  Denmark
Default Sheet metal cooling
I am planning a F4 or F5 amplifier and I have all parts except the heatsinks.
I was wondering if it is possible to use a large (two, mono blocks) sheet of aluminum as heatsink?
The idea is to mount the amlifiers on an MDF buttom on the wall behind the speakers and letting the front plade be at 500x700mm aluplate?
I can see some potential problems:
How thick must the plate be to transform the heat away?
How do I calculate size/effiecency?
Do I need a think adaptor plate where output devices are montted?
Old 10th May 2008, 12:49 PM   #2
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
http://en.wikipedia.org/wiki/Thermal_conductivity
Place an output transistor in the center of the plate, divide the plate in 4 sectors going from the transistor edges to the corners of the plate.
Then set up a differential equation for the cross section plate area A from the transistor edge to the edge of the plate.
Think the transistor edge at say 50C and the plate edges at ambient.
Aluminium conductivity is 237W/M*K, you also know the dissipation number.
Solve the differential equation for x going from 0 to either 0.25m or 0.35m and add up the 4 quadrants.
Looks like Sponge Bob has killed another thread.
Sheet Metal Gauge kafka007 Tubes / Valves 10 15th November 2006 01:40 AM
Metal Oxide vs flamme proof vs metal film ostie01 Parts 28 26th June 2006 06:38 AM
Construction: The best way to cut a hole for an IEC power inlet into sheet metal PaulHilgeman Parts 10 16th October 2003 08:36 PM
Cooling an amp with poor cooling BAM Solid State 8 31st December 2001 04:40 AM
Page generated in 0.05118 seconds (80.67% PHP - 19.33% MySQL) with 10 queries
