diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Ono Bipolar Transistor Replacement (http://www.diyaudio.com/forums/pass-labs/122821-ono-bipolar-transistor-replacement.html)
rsbay 10th May 2008 08:26 AM
Hello,
what is the best replacement for
2SA991
2SC1844
in the Ono phono preamplifier?
Thanks for your help
Ralph
Nelson Pass 11th May 2008 04:59 PM
These are listed as low noise and high gain, with a 60V rating.
In point of fact, the critical ones are the NPN cascoding on the MC stage
and the current source for the diff pair, where they will see about
30V.
I don't know of a direct replacement, but looking at my parts supply,
I would try the MPSA18 or MPS6571 for these two parts and use
a high quality 60V device elsewhere.
chris86 13th August 2013 09:52 PM
@ Nelson
is it possible to replace the 2SA991 and the 2SC1844 with 2SA992 and 2SC1845? I think thats no problem or?
regards
Chris
h_a 19th August 2013 06:12 AM
You can use any bjt with suitable voltage rating in these positions, however, noise performance may suffer.
Looking at the datasheet of the 2SC1845, it will work as it has a 120VCE rating, but it will have a bit higher noise level (look at the noise plots).
ticknpop 19th August 2013 02:23 PM
2sc1844 is available
B+D Enterprises - 2SC1844
2sa991
http://www.ebay.com.au/itm/2SA991-Tr...-/161024086110
permaneder 21st August 2013 07:45 PM
Originally Posted by h_a (http://www.diyaudio.com/forums/showthread.php?p=3600894#post3600894)
Try 2SA872(A)E and 2SC1775(A)E
chris86 21st August 2013 08:50 PM
Thanks, ive the focus on the 2SA970 for the 2SA991 and its available without problems.
Chris
permaneder 21st August 2013 08:57 PM
Originally Posted by chris86 (http://www.diyaudio.com/forums/showthread.php?p=3604338#post3604338)
Chris
Note: 2SA... and 2SB... are PNP and 2SC... and 2SD... are NPN
chris86 21st August 2013 09:58 PM
Yes, thats clear... but thanks ;-)
Copyright 1999-2017 diyAudio
