Old 11th March 2003, 01:14 PM   #1
Send a message via ICQ to TjongKristian
Default Last Advice
I have one channel ready to be assembled and plugged into the electricity. Any advice? The toroid is 1KVA at 31-0-31-0. Caps filtration at 22,000 x 6. Should I put inductors on the rail or resistor will do (which value of the resistor should I use?)? I hope I won't see any smoke when I turned it on. Thanks.
Old 12th March 2003, 08:57 PM   #2
Yonnat is offline Yonnat  France
Send a message via ICQ to Yonnat
nice monster, it looks like the mine you can see it on this forum.
For the power rails I use 0,2 ohm not inductive resistances on each rail after the first capacitors, that makes a cut off filter for frequency over 100hz, you will loose 1,6 volts on the supply if you are using one transfomer for the both channel on a Aleph30 (I don't know wich Aleph you are building).
Another idea is to separate the ground rails until the end like this
+-------------------- + out
gnd+---------------------
] gnd out, here you connect the wire
gnd- ---------------------
- --------------------- - out
it is better to do it this way, so you have a good gnd reference without fluctuations
And the last, separate the gnd wire for the pcb board, one wire for the high current and an another one for the entry level, on my PCB I have separated the gnd for these two level and they are only connected on the common gnd out point.
Good continuation.
Yonnat.
Old 12th March 2003, 11:19 PM   #3
The one and only
Nelson Pass's Avatar
One word: Variac
Old 12th March 2003, 11:40 PM   #4
diyAudio Retiree
Default I thought it was plastics......
Mr. McGuire: I just want to say one word to you - just one word.
Ben: Yes sir.
Mr. McGuire: Are you listening?
Ben: Yes I am.
Mr. McGuire: 'Plastics.'
Ben: Exactly how do you mean?
Mr. McGuire: There's a great future in plastics. Think about it. Will you think about it?
Ben: Yes I will.
Mr. McGuire: Shh! Enough said. That's a deal.
Sorry Nelson. As a fellow film fan you know I couldn't resist!
Old 12th March 2003, 11:59 PM   #5
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
what are the minimum requierements when looking
for a variac?
like... a minimum 10 amp output?
Old 13th March 2003, 12:10 AM   #6
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
My ears are burning.....
Old 13th March 2003, 12:24 AM   #7
grataku is offline grataku  United States
An alternative to variac: thermistors. Carefully placed between the caps. Like Nelson did in the XA200...
Also, do yourself a favor, don't break any taps. On the 23rd hole for the 23rd output mosfet you'll feel like punching your way through, resist it or you'll be
Old 13th March 2003, 12:27 AM   #8
karma is offline karma  Canada
karma's Avatar
Default .
sweet
Old 11th May 2003, 04:41 PM   #9
Default The day of REVELATION
Finally, I connect everything and turn it on. Only one channel that is working now, still waiting for more additional heatsink for the other channel. My 1st impression of the amp was it sure really hot. I do not have the temp mesarument device yet, perhaps the coming monday. Sound wise, this amp open up my eyes (ears actually). Sound coming out from my BW 602 is much more defined and set loose with out anything in between. Could not wait for the other channel to be completed.
Old 11th May 2003, 04:44 PM   #10
Default BTW, it is Aleph 2
Measured DC 30mV
first amp advice prezden Class D 2 18th November 2008 10:05 PM
TT advice??? geordie Analogue Source 2 30th September 2007 04:04 PM
Advice for an amp wyomoose Subwoofers 1 12th February 2007 08:07 PM
New to DIY, looking for advice flubhubber Multi-Way 1 14th November 2005 03:48 PM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
Page generated in 0.10266 seconds (84.93% PHP - 15.07% MySQL) with 11 queries
