Hi there
I am looking for a transformer for the Aleph 3 amp. The circuit is located at Aleph 3 power supply One of the vendors posted here Avel has various toroidal transformers listed on this website. Can I use any of these ? I am wondering if P/N Y236850 is sufficient? I cant seem to corelate the circuit specs to the transformer specs on the website. If anyone has another vendor from whom they have ordered a similar transformer could they please post the vendors information here along with the specs used to order ? Also what was the approx price? thanks in advance vsr |
#2 |
Sorry, Y236850, will not do; it has 2*25VAC secondaries, which will give you about +/-30VDC...
The specified 2*21VAC transformer is a custom job. Standard voltages are 2*18VAC and 2*24VAC. I where you, I would go for the original schematic by NP. The you can use for example a Y236651 per channel. Without inductors, it will give you about 23,5VDC.. (this is what I did). Then you can use 25V caps etc. Hope this helps,
Mads K |
#3 |
Thanks for your reply. Where can I get the original circuit diagram of the NP Aleph 3?
thanks vsr |
#4 |
MikeW |
#5 | |
Try amps and then legacy products.
UrSv Those who say it can't be done should not stop those who are doing it. |
| Aleph-X transformer | PeterLeest | Pass Labs | 1 | 25th December 2005 10:07 AM |
| aleph X transformer ? | jeclk | Pass Labs | 3 | 20th October 2005 10:33 PM |
| Aleph 5 transformer | billy | Pass Labs | 7 | 26th July 2002 07:50 PM |
| transformer voltage needed for Aleph 4 or Aleph 2 | diy student | Pass Labs | 23 | 28th November 2001 07:54 PM |
| Page generated in 0.07695 seconds (74.21% PHP - 25.79% MySQL) with 10 queries |
