zen #9 WIP - Page 4 - diyAudio
Old 8th May 2008, 06:15 PM   #31
Magura is offline Magura  Denmark
Magura's Avatar
Read the original article, the voltage of the zener string needs to be higher than the output voltage.
Not that it makes up for turning the active device
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 8th May 2008, 07:05 PM   #32
gionag is offline gionag  Italy
wait a second...
on the article (brideofzen.pdf) i saw only 6x 10V zener.
if i look at the pcb, i noticed that i've inverted the pins of the tip...
Old 8th May 2008, 07:27 PM   #33
Magura's Avatar
Originally posted by gionag
wait a second...
Fact remains that you need to stack zeners for 4 volts more than the output voltage in this type of regulator
Magura
Old 10th May 2008, 12:06 AM   #34
the problem with the psu of Boz is fixed....
at the end the problem was the inverted pins of the tip29. i don't print the pcb "MIRRORED"....
i'm a n00b
Old 10th May 2008, 03:06 AM   #35
sandstorm33's Avatar
qionaq-Your Power JFETS are on there way..sent yesterday. 5-10 days according to our local Postal "experts".
Let me know when they arrive....
Old 12th May 2008, 06:57 PM   #36
i don't miss !
thanks a lot
Old 13th May 2008, 10:31 PM   #37
Default BOZ TEST FINISHED!
Hi guys,
today i've tested (thanks to the Magura's Resistors) the Bride of Zen.
this is a photo of TEST-SETUP (my desk is so crowded).
I've listened trough earphones and HE sounds embarassing well...
The input / output cap is a shitty things. how is the best in this kind of application ?
But now, i've at least one doubt, it's important to match the IRFs ? For what bias current ?
Thanks to anyone who are supporting me.
Old 19th May 2008, 11:54 AM   #38
... i've a problem...
what's the reason that i can't reach trough P1 the half voltage of D3 drain ?
when i'm going lowering voltage, at around 32-35 volt che 2ohms resistors became very hot.
what could goes wrong ?
Copyright 1999-2017 diyAudio
