zen #9 WIP - Page 3 - diyAudio
Old 5th May 2008, 11:58 PM   #21
gionag is offline gionag  Italy
Originally posted by Magura
Now our Italian friend is but 2* 0R5 3W resistors short.....any takers?
Magura
Originally posted by yggdrasil
I can fix the 0R5/3W. Send me an e-mail.
Johnny
thanks for proposal but now is just arrived a delayed shipment from digikey with 5 of mox 0.47 3W. this resistor is not yet needed.
Old 6th May 2008, 12:41 AM   #22
Magura is offline Magura  Denmark
Magura's Avatar
In that case you're all set for the weekend
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 6th May 2008, 12:43 AM   #23
Magura's Avatar
BTW, your IRF610 without mounting hole is no problem, just make a bracket of a coin with a hole
Magura
Old 6th May 2008, 11:05 AM   #24
Good luck with your build.
Old 6th May 2008, 10:11 PM   #25
thank you !
today i've finished the pcb for BoZ.
tomorrow i'll start to put on some components.
stay tuned !
Old 8th May 2008, 09:30 AM   #26
"In the beggining was BoZ"
Click the image to open in full size. Click the image to open in full size.
There aren't so much components on it, but i solder only the components that i already had at home.
Today i made an order from digikey with the rest of components.
And a little question: if I get a longer cable between IRFP240 pins and PCB can i affect performances ?
Old 8th May 2008, 12:52 PM   #27
Magura's Avatar
No, the wires can be very long, without causing any problems.
Magura
Old 8th May 2008, 01:40 PM   #28
OK... perfect
but now i have another problem:
today i test the PSU board for BOZ.
i supply that with a 220V - 60V trasformer.
after the bridge and the C1 (filter cap) i have 86V.. and that's OK ! but, at the output of the psu i have only 48V... instead of 60V.
i checked the connections and they seems ok.
Attached you found the PCB that i used. anyone has idea ??
i never understand the polarity of the zeners. how i have to mount on this pcb ? i put them with stripe on the BASE pin of the TIP29. And also, i used the TIP29CFS instead the TIP29CGE, there are differences ?
Old 8th May 2008, 03:08 PM   #29
Magura's Avatar
You're 1 zener short, that is, if you use 9.1v zeners.
Magura
Old 8th May 2008, 05:50 PM   #30
i use a 10v zener...
i think that i've inverted the pins on the TIP29.
Copyright 1999-2017 diyAudio
