Old 21st April 2008, 05:55 PM   #1
Default aleph L+aleph 3+aleph 3
Is it possible for an aleph L to drive successfully two aleph 3 for
vertical biamping?
It will see only half impedance of the poweramps (11500 ohm).
Thanks.
Old 21st April 2008, 07:33 PM   #2
Not a problem.
Grey
Old 23rd April 2008, 02:35 PM   #3
I tought it was impossible for the "before 3 o'clock" positions of the attenuator; isn't it a passive preamp in that situation?
Thanks .
Stefano
Old 23rd April 2008, 05:17 PM   #4
The one and only
Nelson Pass's Avatar
Depends on the version. In either case, no problem.
Old 23rd April 2008, 05:41 PM   #5
Thanks mr. Pass,
so I can use two Aleph 3 for biamping without driving problems.
I thought I had to use necessarily the Aleph P.
Very good.
Old 23rd April 2008, 09:19 PM   #6
The question you should be asking is if your preamp can drive your crossover...after all, that's what the preamp will see, not the Aleph 3s.
Grey
Old 23rd April 2008, 10:01 PM   #7
Hallo Grey,
this is passive vertical biamping (without electronic x-over). Maybe I'll use a simple 6db/oct. filtration for high frequencies.
Regards.
Stefano
Old 23rd April 2008, 11:41 PM   #8
What sort of filter are you using and is it before or after the amp(s)? Assuming the filter to come before the amp (by far the most common arrangement, though I've known one or two people to try the filters afterwards), the impedance presented by the filter itself is the issue. One you get beyond the pass band, the rolloff presents an increasing impedance to the preamp. For example, if you have a 2kHz high pass filter for your midrange and tweeter, 100Hz signals find a pretty high impedance (how high depends on the filter and questions such as what the crossover slope is).
Grey
Old 24th April 2008, 05:58 AM   #9
I'm not doing this by myself (I'm not even able to solder ),
But the cross is about 1000hz (Tannoy custom with hpd 12") and the technician said he will put the simple filter before the left channels of the amps(the right ones will remain full range for woofers) , maybe before the left outputs of the preamp.
I'm not able to explain the thing better than this,excuse me.
Regards.
Stefano
Old 24th April 2008, 09:24 PM   #10
You should be just fine.
Grey
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.07848 seconds (88.04% PHP - 11.96% MySQL) with 10 queries
