Old 22nd April 2008, 02:03 AM   #11
Hello MyWing, Perhaps it's just me, but when I look at the first picture, it appears that the second fuse socket from the right in the row of four is broken. I can't say for sure, but you may want to take a closer look at the picture. If that's busted, then what else may be wrong?!
Peace,
Dave
Old 22nd April 2008, 10:55 AM   #12
Mywing is offline Mywing  Italy
Thanks of the signaling Dave,
I will talk about that with to the seller.
Cheers
Old 22nd April 2008, 03:35 PM   #13
Prego MyWing!
Old 11th May 2008, 09:30 PM   #14
My "new" old 400A has arrived .
But I had a bad surprise. It sounds arsh, woody, dry, with absent highest frequencies absent, annoying mids...
This happens with both my preamps (a restored Threshold Sl-10 and an AR SP10).
The situation improves slightly with low volume...
What may be happened? The seller assured me that the unit is totally original and any component has been changed.
The only explanation I can give this sonic degradation is the ageing of capacitors and other internal components. What do you think about?
Who has had the opportunity to restore a 400A, has noticed a similar deterioration sound which I heard before the restoration?
Has someone an opinion about that? Nelson ... ?...
Another question: I came in mind that all this could be caused by a probable incompatibility with my Snell A. Perhaps does 400A suffer 4 ohms speakers?
Any suggestion and opinion are well accepted.
Old 12th May 2008, 12:23 AM   #15
The one and only
Nelson Pass's Avatar
It looks like you will experience the pleasure of making the amplifier
much better.
A number of people in the forum have worked on these. Obvious
candidates is replacement of capacitors, replacement of connectors,
fuse holders and whatnot, and bias adjustments.
As a rule the semiconductors do not need replacement unless there
is an obvious problem.
Old 12th May 2008, 08:35 AM   #16
Thanks for answer Nelson,
could you suggest a caps' brand/kind for the replacement? And above all, how to adjust the bias?...
Besides I would like to know the opinions of whom has materially completed a similar restoration .
Cheers
400A or Stasis 3? Mywing Pass Labs 6 4th November 2007 06:53 PM
Threshold 400a Rolexmonger Pass Labs 10 12th July 2007 04:51 AM
Threshold 400a Rolexmonger Pass Labs 1 22nd March 2007 08:03 AM
Threshold 400A HELP !! Airedale Pass Labs 2 16th February 2005 10:56 PM
Threshold 400A johnsciolino Pass Labs 1 29th August 2004 06:50 PM
Copyright ©1999-2013 diyAudio
