Hi all,
I've just embarked on putting together a mini-aleph for my full range speakers. I've really only done work with tubes before so be gentle with me Believe it or not, but its actually quite hard to locate the info readily on all of this stuff!! So I've 2 questions: 1. heatsink: will a heatsink measuring 3" by 8" with 1 1/4" vanes with a 1/4" solid plate bottom be enough for one board? My second choice is one thats 4" x 8" with only 1" vanes. 2. Will a TO-220 mounting kit (insulating pad and bush) fit the TO247 package that the mosfets are? TIA and sorry for what must be obvious questions.... Fran |
#2 |
Did it Himself
The TO-220 pad is too small for the TO-247. You probably won't need a mounting bush as the TO-247 hole is surrounded by plastic usually.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 | |
#4 |
The BER118 thermal pads will work for TO-247 or TO3-P -- they are available from DK
You need to specify the number of fins if you want to guestimate the thermal impedance of the heatsink -- assuming 10 theta = 2.1 |
#5 |
OK,
thanks for that. The insulating pad then would be this one: farnell link jackiinj: I'll download one of the online calculators and see. AFAIK, the mini-A will dissipate about 45W per side so I'm aiming for a heatsink of about 1deg/W. Something like this one, but the one I have to hand has deeper fins: second link What do you guys think? Fran |
#6 |
HI
for FR aren't more appropriate the F2 current source ?
#7 |
I hear people recommending the F4 as well so I don't know for sure.
Fran |
| Mounting a Heatsink | Bigman | Chip Amps | 8 | 13th December 2007 02:00 PM |
| mounting of outputs to heatsink | bigpanda | Solid State | 10 | 27th April 2006 10:44 AM |
| Help - Mounting transistor to heatsink | vsr123 | Pass Labs | 10 | 17th April 2003 11:43 AM |
| Heatsink mounting. | JoeBob | Solid State | 3 | 21st January 2002 02:51 AM |
| Heatsink mounting issue | nikami | Solid State | 2 | 3rd April 2001 09:15 PM |
| Page generated in 0.09441 seconds (77.38% PHP - 22.62% MySQL) with 10 queries |
