Old 7th January 2011, 12:29 AM   #9751
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Originally Posted by 6L6 View Post
I have a 4U 300mm deep Modu on order. I have conversed with a board member who has used that exact chassis with wonderful results. I hope to have the amp done within a week of it's arrival from Italy.
That's great to hear, I've designed my back panel and working on side panel (heat sink - drill & tap). It's nice that they do that at a reasonable rate.
I've created the panels with front panel express, and export it as a dfx file.
Old 7th January 2011, 01:24 AM   #9752
Lerg is offline Lerg  Canada
Originally Posted by a.wayne View Post
So the Toshiba's for sure are better sounding than the IRFP's......
I would say that it is a safe bet that the Toshiba transistors will sound different. Better is a personal preference, so that is a firm maybe.
Old 7th January 2011, 07:35 AM   #9753
EUVL is offline EUVL  Europe
Nelson has also treid all 3 types (Tos, IRF, FQA) and posted his opinions here.
Why not search for his comments.
Patrick
Old 7th January 2011, 11:54 AM   #9754
flg is offline flg  United States
flg's Avatar
Maybe here?
F5 Listening Impressions & Discussion
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 7th January 2011, 03:52 PM   #9755
Thinking about PSU size for dual mono F5, what can and cant you do.
I was thinking going for less total capacity but instead focusing on ripple current and low ESR.
Wouldnt a lower total capacity than what pass uses in his PSU, but high ripple current and low ESR be better than a huge total capacity but less ripple current and higher ESR?
Can get some very high ripple 2200 uF 50V 105 C caps, around 2.5-3.5A pr cap. Ten of these pr rail would give you 22000 uF pr rail but 25-35A total ripple current and very low ESR.
Am I completely on the wrong track here or do I have a point??
Old 7th January 2011, 04:02 PM   #9756
You are absolutely on the right (but very expensive) track :
Balanced F5 question
The PCBs that connects all these caps together are 110x80mm, double sided 210um (6 oz. I thnk) copper. Copper costs money.
Patrick
Old 7th January 2011, 04:22 PM   #9757
massimo is offline massimo  Italy
Originally Posted by EUVL View Post
Copper costs money.
.... and now more than ever! Look how this (precious) metal increase its value in 2010.
Old 7th January 2011, 04:32 PM   #9758
Patrick
Ah, thats just, insane.
But think I'll stay at 2-3 oz. Should be sufficient.
Most likely making a CRC supply, with 5 x 2200 uF caps - resistor - 5 x 2200 uF caps pr rail, as a minimum, might go nuts and add even more caps, but lets see later on. Caps can be really expensive, even small ones, if you want high ripple current.
Old 7th January 2011, 04:36 PM   #9759
what's wrong with assembling using copper wire, solid core or stranded?
Too much inductance?
What about rCRCRCC?
r=secondary resistance
C=4*2200uF
R=1r0//1r0//1r0//1r0
Buy 100off 2200uF and negotiate a big discount.
regards Andrew T.
Old 7th January 2011, 04:37 PM   #9760
Digi-Key - P10335-ND (Manufacturer - EEU-FC1H222)
At 1000 pcs, they cost less than 1 USD per piuece.
Patrick
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.18697 seconds (70.17% PHP - 29.83% MySQL) with 11 queries
