#9701 |
#9702 |
Thanks flg, but neither of those guys have 2sk1530/2sj201 for sale. And I'd still like to know if the two mosfets that I mentioned in post #9697 would be OK in this amp; they're cheap too.
#9704 | |
but I have looked at hundreds of mosfets the last few days, and every time I look at a nice strong one, capacity goes up ![]() why not the original IRFP9240/240 Im looking at maybe using the newer IRFP9140/140 someone even suggested 9140 with 240 hey, I can get all 4 outputs for something like 20USD also easier and much cheaper to repair, should it be needed who knows, maybe theres a completely new and much better mosfet in a couple of years one should really hope so, eh ![]() anyway, I can live with the second best
#9705 |
Regarding Zhou Fang, I think you would have to e-mail him, you could be right. Sometimes he takes awhile to get back to you. Just PM him and ask.
Regarding Blues, looks like he has 15-20 pairs on his spreadsheet??? Regarding the FQA28N15, I've used it in ZV4 and I liked it. I still have 10-20 ![]() I don't know about the other one. The C you quoted is double the FQA28N15. A typical sustitute pair would be the FQA12P20/FQA19N20. But as I'm sure you realize, few will be as complimentary as the Toshiba's.
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#9706 |
Lars... I'm ashamed to say
... I was looking for something on the cheap. I did notice the high capacitance, hence my question. In order to get a few good matches of irfp240/9240 I'd have to buy quite a few, no? The price is about $5 a piece, at mouser. In comparison, the fqa36n15 is $2.62 a piece, and the fqa28n15 is just $1.67 a piece. flg, I bought stuff from Zhou Fang before, so I'll just ask what he's got. If I could get a couple of matched pairs at a reasonable price, sure. Regarding the fqa12p20, it seems to be an obsolete part, hard to find. I got a chunky tranformer, a bunch of Sprague 33mF caps, two hammond reactor 102mH/2A chokes for the psu. Got tons of 2sk170 and a few of 2sj74. Have a case and large heat sinks as well, but still missing the output mosfets, 3W resistors, and and zetex parts. |
#9707 |
For the matched toshiba I think that EUVL may be selling or can give you same pointers on where to get them at least in the EU may be worth looking at the balanced F5 tread.
For the Farchild I have 100 each of the FQA12P20 and FQP19N20C I could not get the FQA19N20 those are reccomended substitute by Papa in his paper Please note FQP19N20C is a TO220 case I can't see any differencein the speck apart from slightly lower current and power dissipation. Is a bit to early for me to sell any but I can alwayse help a felow Diyer send me a PM if you get stuck Maybe some one more experienced can point out the difference between the FQP and the FQA. Hi Mellonhead Agree 100% corectley vired equipment does not need the thermistor. Agree 100% about the "cowboys" One thing is for shure the noise generated by the ground loop is there because there is a potential difference between 2 point of the circuit. If the potential difference is zero = no noise The way I see this is either zero potential difference which is impossible or no loops for the potential difference to take place and so no ground loop The way I was suggesting is to avoid making a ring circuit and use star or bus of star circuit as you say only one conection I was proposong to cut the screen cable as the reciving end if there is a ground loop So just enjoy the noise one minute and then snip noise gone maybe big maybe as it can be a real pain to stop the electrons from getting boucing up and down the most silly places CL60 to stop the noise sorry don't think so maybe reduce it a litle bit or maybe make it worst as we are back to zero potential difference = no noise There is one thing I am not shure I understand IMO there shuld be no current at all flowing troug the Earth cable except when there is a fault condition. now 0 current is impossible to get More realisticaly here in the UK there is a safe limit apcepatable for domestic systems they have RCD at 30mA and in Hospitals the maximum current is limited to 5mA In regard to the CL60 TH1 could it be there to reduce the tumph on the speakers at start up? |
#9708 |
#9709 |
Thanks bksabath, I think I'll try the ones I mentioned, and when I come across a good deal on the toshibas I can always replace the fqas.
Just for laughs I ran a quick fft test with the irfp and with the fqas. Only one mosfet (not a paralleled pair), input 1kHz 1V p-p, output about 6V p-p into a 6R load, with about 1.3A bias in the output mosfets. The fft on the left is with the irfps, the one on the right with the fqas. Not so different, really. The frequency response is obviously not as good with the fqas, but still going well past 300kHz in a straight line. Haven't run a stability analysis yet. Anyway, it's just for fun. I can always get the proper devices if this isn't working well. |
#9710 | |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
