F5 power amplifier - Page 950 - diyAudio
Old 24th December 2010, 02:06 PM   #9491
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
layout finished
Old 24th December 2010, 04:16 PM   #9492
anilva is offline anilva  India
Default Advice on F5 with 2SK1530/2SJ201
I am planning another F5 build but with Toshiba MOSFETs. I have found the attached schematic in one of these threads. Just wanted to check if this is the right one that I am looking at? There seem to be so many discussions on this, just wasn't sure, which one.
Cheers
Old 24th December 2010, 04:25 PM   #9493
EUVL is offline EUVL  Europe
IF single ended (+/-24V rail) then R11, R12 should be 0R47.
And you should replace P1, P2 with fixed resistors after trimming.
Voltage across R3, R4 more like 3V.
Schematics not proven, so build at own risk.
Patrick
Old 24th December 2010, 04:39 PM   #9494
Patrick
Should P1 and P2 behave any differently than a stock schematic to mandate replacement with fixed resistors? The reason I am asking is because that would be the case even in the case of IRFs isn't it? Or is it because of increased sensitivity of the Presets....with the combination of Toshiba Mosfets.
Thanks.
Merry Christmas to everyone!
Old 24th December 2010, 05:20 PM   #9495
Root2 is offline Root2  United States
Root2's Avatar
Originally Posted by Nelson Pass View Post
As many of you know, the F5 power amplifier design is done and is
merely awaiting delivery of the issue of AudioXpress which was
scheduled to be mailed April 10.
I feel that it's important to support AudioXpress, a magazine with
which I have a 35 year history, and which also serves as a
mainstay for the DIY comunity. Lately they have kindly printed
projects that I had already posted on the web, but I decided that
they deserve a little better than that.
Coincidentally, I had surgery of the 10th, and having apparently
survived, I am typing this from my bed.
Do not try to lift an XA200.5.
Hi Nelson,
Nice KISS circuit similar to a MC stage I made when I was with Magnum 1979 I dig it and put it up for you to see.
Colin Wonfor
Old 24th December 2010, 05:39 PM   #9496
nar is offline nar
nar's Avatar
Thanks.
Fixed resistors will exhibit less thermal drift, as their PPM temp. coefficient is smaller
Just choose the right type of resistors, some Dale RN/RL/CMF type should run just fine
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 24th December 2010, 06:19 PM   #9497
regiregi22's Avatar
Originally Posted by Zen Mod View Post
yes - it will work ;
be sure to have some sort of (balanced , too ) volume control between DAC and amp
My DAC has already a volume control, so no worries
Originally Posted by bobodioulasso View Post
Still 25w class A power but a lot more in class AB
Are you saying that regarding my question? If so, why do you get less "class A power" when doing that way?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 25th December 2010, 12:05 AM   #9498
bobodioulasso's Avatar
The bridged F5will bring twice more output voltage but it will also leave class A when running at more than 2.6 Amps into the load.
To get full class A power, you need more output devices, more global bias, more heatsinking, different PSU.
Old 25th December 2010, 12:57 AM   #9499
ra7 is offline ra7  United States
Hey guys,
I'm planning to use an inductor in the supply. I know there have been several posts regarding this approach. Any ideas on what to use? Part numbers?
About 2mH, and large guage, yes?
Thanks!
Old 26th December 2010, 02:36 PM   #9500
regiregi22's Avatar
Originally Posted by regiregi22 View Post
Well, then mine is sitting between 55 and 60: I don't really know how hot is too hot, I come from the Gainclone world
Two days ago I received a digital IR thermometer from Dealextreme, a cheap one. I've tested it against my body and I got 36, so I consider it "quite" accurate despite its price.
After 24h of F5 on, some parts of the heatsink measure as high as 67. I get .520v across the source resistors. Setting them to 0.600v seemed a bit high. I am considering getting it even lower for long term endurance.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright 1999-2017 diyAudio
