F5 power amplifier
F5 power amplifier
Old 21st November 2010, 07:27 AM   #9201
cviller is offline cviller  Canada
cviller's Avatar
If you are using the drawings to measure something during your build, I will recommend using one of these drawings (letter and a4):
http://viller.eu/audio/2009jan_gbf5/...ntassembly.pdf
Old 21st November 2010, 12:25 PM   #9202
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Thanks.
Do you happen to have anything with dimensions on it? I'm going to transfer it right to a cad drawing.
Old 21st November 2010, 12:28 PM   #9203
cviller's Avatar
The size is 10x5cm
Old 22nd November 2010, 01:55 PM   #9204
Has anyone come across an illuminated switch for the F5 with 2 led outputs?
I was hoping I could find a switch that would allow me to light up 2 sides of it, independently from the power. I'd just connect the led outputs from the output boards to each side of the switch (instead of drilling out additional holes for them on the front panel of the chassis).
Old 22nd November 2010, 08:22 PM   #9205
frags is offline frags  Canada
I've just finished building first channel of my F5. During the test phase I observed the following:
1. It tends to oscillate (about 1MHz) with high capacitive load even if no input signal is provided (0.33uF used and input shorten to the ground).
2. It tends to oscillate with square input signal with fast rise/fall times (100ns, 4Vpp input signal) . As well with such sharp square signal it gets significant overshoot if 2Vpp signal is given for example.
So, to solve these problems I've added 150pF capacitor from JFET gates to the ground.
No overshooting and oscillations and the bandwidth did not reduce for listening purposes.
Adding more values in gate-stoppers did not help at all.
Any comments?
Old 22nd November 2010, 09:31 PM   #9206
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
I think it's public knowledge that you don't hook a capacitor
directly across the F5 outputs.
If you wish to tame your square wave response and you are
willing to introduce a capacitor to the circuit, the best place
is across the 50 ohm (two parallel 100 ohm) feedback resistors.
Old 22nd November 2010, 10:24 PM   #9207
Thank you, Mr. Pass.
But my second test (an oscillation and overshooting with fast rise/fall square signal - 1kHz, 100ns edges) was done w/o any capacitive load (only 8Ohm resistor).
You said that adding a few pF capacitor to JFET gates would solve the overshooting issues, but it looks like it was not enough (typical JFET input capacitance is about 100pF at zero Vgs).
Old 23rd November 2010, 12:25 AM   #9208
nar is offline nar
nar's Avatar
As a cure for oscillation problems, you could also add some series resistance with the gates of the jfets - Q1/Q2 - (100 to 221 R for example) and try to get higher resistor values for R13 - R14 (maybe 100 / 221 and perhaps as high as 1k, with tradeoff regarding absolute bandwidth)
Hope this helps
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 23rd November 2010, 12:43 AM   #9209
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Installing small decouping electrolytics on the board rails can also lead to oscillations.
Old 23rd November 2010, 01:31 AM   #9210
nAr,
I'll try JFET gate resistors on my second channel. Increasing R13-R14 (330Ohm) value did not help at all.
Looks like the source of oscillation is JFETs, not MOSFETs. The oscillation happened only with high level square signal with sharp edges.
Anyway, adding 150pF capacitor to JFET gates cured the problem.
bobodioulasso,
I have no decouping electrolytics on the board rails.
Thank you, guys.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
