F5 power amplifier
F5 power amplifier
Old 27th May 2008, 03:45 PM   #891
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
You can do that, no changes. Just drive each input with the
opposite polarity of the same signal.
Old 27th May 2008, 04:16 PM   #892
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
F5 power amplifier
What type of water proof marker should I use, not a Shapie permanent marker I suppose?
I believe that a Sharpie type marker is exactly what they use..
After, you scrub it off using I dunno - laquer thinnner?
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 27th May 2008, 04:42 PM   #893
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
I use any black-color oil paint.
I use the toothpick for the drawing.
Finally, I rub off the paint, using a hard luffa...
Old 27th May 2008, 05:01 PM   #894
sandstorm33 is offline sandstorm33  United States
sandstorm33's Avatar
Sharpie works fine. Clean the board with a brillo pad and then use a degreaser . Draw your pattern with the sharpie and etch with 2 parts peroxide and 1 part muriatic. Be careful with the mixture ..I do the etching outdoors. When etch is complete wash board well and drill holes. Then I coat the traces with flux from flux pen from mouser and let flux dry. Then I flow solder on the traces.
I have also drilled holes first but that requires laying traces out twice.
The reason for flux solder treatment is to cover pinholes after etch. The sharpie is not the greatest mask. You might do better with Babo's oil paint .I imagine a tube of artist's oil would do the job.
Old 27th May 2008, 05:03 PM   #895
Forgot the after etch brillo pad to remove sharpie ink.
Old 27th May 2008, 05:04 PM   #896
The one and only
F5 power amplifier
"We take our obsolete technologies and turn them into art"
- Marshall McLuhan
Old 27th May 2008, 05:16 PM   #897
Goffe is offline Goffe  Sweden
I made some changes, the J-fets are together and the feedback resistors closer. Dimension 10x3.8cm
Any advice please?
/Goffe
Old 27th May 2008, 05:45 PM   #898
juma is online now juma  Germany
juma's Avatar
Default Home-made PCBs
Guys, this is how I do it:
- You print on paper the published picture (it's a bottom view of the PCB - take care with dimensions)
- Scotch tape the piece of paper over the cleaned copper surface
- Drill the holes
- Clean it again (acetone, nail polish remover...)
- Use the water-resistant permanent marker (Staedtler, Faber-Castel...), with a, preferably, hard tip sized 1 mm or smaller to draw the traces exactly like they are on the paper you used for drilling
- Now you etch it like described ( H2O2 + HCl )
- Clean the marker traces with acetone
- Cover the copper traces with non-acid soldering grease (that's the name used here - I don't know the name of US equivalent - it's a greasy substance that makes soldering easier and quicker)
- Use a small quantity of soldering tin to cover the traces
- Clean the grease (alcohol, acetone, dish-washing detergent...)
Your PCB is ready. The success mainly depends on how clean the copper is before the drawing - don't touch it with your fingers.
One more thing: No brillo-pads or similar stuff - no abrasive materials - we don't want to mechanically hurt the copper traces. Acetone on cotton-ball and detergent on soft sponge will do the cleaning perfectly.
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 27th May 2008, 07:58 PM   #899
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
Who mentioned tweaking R1/2 ? -
Old 27th May 2008, 08:01 PM   #900
Blitz is offline Blitz  Germany
Thanks, Nelson, I will start the work immediately, last question: is the heat dissipation similar to the F4 or much lower or much more ?
So, could I get two F5 (so four channels) into a case which would require normally one F4 (two channels)...?
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
