#881 |
not politcally affiliated
JUMA,
What software did you work with? That is a really nice layout. Anybody got any recommendations on an Etching kit in the states?;otherwise, I will wire this Point to point. Mike |
#882 | |
as near as I can figure, that particular mosfet was heated up a little when I re-soldered the wires to the terminal block I was using as a test jig. The mosfet was dumping heat to the heatsink it was pressed against faster than it was heating up. Hence, Vgs went up as I watched. for anyone who didn't notice and who has a pile of IRF240's laying around (and I can't imaginine why any Passaficianos would have those...... ) -- Mouser has the SFH9240's in stock, and they are inexpensive.JJ |
#883 |
Very nice layout Juma!
Very nice layout Goffe! ![]() I have etched my boards and started populating them, but a funny thing happened to me on the way to mounting the output devices and drilling the heatsinks ... I got this crazy idea and I blame it all those crazy fools in the full-range forum ... I put everything on hold for now to build a CNC router table I'll be back one day to complete my F5, hopefully before summer's out
#884 | |
#885 | |
It took me a weekend to build one: The Elektor Conlinbus Profiler. Should let you get back to the real interesting F building activities real quickly. |
#886 | |
Mike, you don't need t no itching kit read this:http://www.diyaudio.com/forums/showt...81#post1073081 |
#887 | |
The F5 design is so spare in the number of parts there's no reason it couldn't be put together on RS proto-typing boards. |
#889 |
Juma, thanks,
Okay, So I will try to spell it out for myself.. so your method is to tape on printout for drilling holes (got to find real tiny bits, hmmm) Then I suppose take this printout off and then handraw the circuit with a marker of the copper PCB sheet. What type of water proof marker should I use, not a Shapie permanent marker I suppose? More like a crayon? ![]() Add into Hydrogen peroxide and Muratic acid solution. Then add flux, and then solder the traces on I would assume with some real wide Solder with a wide tip iron. Sounds like cooking... It will then look like my old Hafler DH-200 boards. Did I misunderstand something? Mike: |
#890 |
THis questions has been askd a couple of times...I searched the thead, but do not really understand the correct answer, so please be patient with me:
As the bridged version of the F4 sounded so much better on my speaker: Can I simply use two F5 as a bridged amp without any changes (like in the F4) ? If not: What needs to be changed ? THX a lot |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
