F5 power amplifier - Page 871 - diyAudio
Old 19th August 2010, 10:44 PM   #8701
Tripmaster's Avatar
Hi
This is how it is at moment, but I have tried several different layouts to date and the low level hum hasn't changed. I'll draw a the layout of the preamp tomorrow evening.
Old 19th August 2010, 10:53 PM   #8702
LucasAdamson's Avatar
Originally Posted by Russellc View Post
If its silent with the inputs shorted, wouldnt that indicate something upstream,i.e. whatever is serving as pre? (or source?)
russellc
That's what I was thinking.
I would try disconnecting the pre-amp signal earths from the pre-amp chassis earth, so that they earth down the RCAs to the power amp and into the star ground there.
Lucas
Old 19th August 2010, 11:02 PM   #8703
Have you tried removing the thin cable from the RCA to the CL60 altogether. It shouldn't be necessary as if the RCA earth goes to the board, it makes a kind of small cable signal sub star, which is good.
In fact, I think it's a no-brainer. It shouldn't be there.
Also, think of your PS board as the star. It's logical, especially as it has a large ground plane.
Lucas
Old 19th August 2010, 11:14 PM   #8704
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
absolutely, it looks like a ground loop
RCA jack input is isolated from chassis, and should only connect to amp board
Speaker "negative" should connect to power supply CT point, either directly, or on amp board
Chassis ground should be isolated from Power supply CT by resistor, or the way Nelson does it, via thermistor CL60
sometimes we know very little, and sometimes we know too much
Old 19th August 2010, 11:21 PM   #8705
Jacques Merde's Avatar
Originally Posted by EUVL View Post
This article explains why you might want to degenerate the 2SJ74 to make it truly complementary with the 2SK170.
Patrick
EUVL,
What's the impact on amp performance? Have you had a chance to listen or do any measurements?
You have PM.
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Old 20th August 2010, 12:03 AM   #8706
EUVL is offline EUVL  Europe
Thanks for your PM.
I have never used the circuit without this "correction".
But at least on simulation, you do get lower (even order) distortion.
It is easy enough to try out, and is also easily reversible.
Patrick
PS I am not aware that there are other suppliers for 2SK170 & 2SJ74 other than Toshiba.
Old 20th August 2010, 03:26 AM   #8707
expert in tautology
bear's Avatar
You don't need to do a thing... Patrick is talking about optimizing the input pair to track perfectly or nearly so by using some degeneration and being able to select the devices from a large batch based upon rather precise Idss - something most people can not do for several reasons (no curve tracer, no batch of devices...). Just build it, the amp sounds great (although the sound can vary all over the map depending on the parts and bias used), and some people prefer the slight increase in some harmonics that happens when the devices are not perfectly matched!
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 20th August 2010, 06:17 AM   #8708
Someone sent me a PM and asked for clarification regarding manuafacturer of 2SK170 / 2SJ74.
In post #8700, Russellc wrote "Is this the case with all 2SJ74 and 2SK170, or just the Toshibas? ...."
My reply in post#8707 was " PS I am not aware that there are other suppliers for 2SK170 & 2SJ74 other than Toshiba."
I meant there is no other manufacturer for these JFETs, except Toshiba.
A bit of twisted English that might be difficult for non-native speakers.
So my apologies.
I am aware that you can get LSK170 which is supposed to be equivalent.
I have yet to see a LSJ74 even though it has been constantly promised for the last 5 years or so.
Patrick
Ps for those of you who is interested in Nelson's comments :
http://www.diyaudio.com/forums/analo...ml#post2278053
Old 20th August 2010, 06:25 AM   #8709
As to whether you want to try this or not, I leave it up to you.
Different people chase after perfection to different extremes.
I made the data available for all. So everyone can decide for himself.
You don't need a large batch of both FETs to try these. Stick to the j74 you have, and get some K170s.
There are multiple vendors here selling them at almost dumping prices.
You can even select your own matched pairs from an excel sheet of measured Idss with one guy.
Cost you 6 USD only.
Six dollars to give yourself a chance to decide whether you want even less even harmonics is for me a very tempting experiment.
Patrick
Old 20th August 2010, 06:38 AM   #8710
Blues is offline Blues  United States
Blues's Avatar
Six dollars to give yourself a change to decide whether you want even less even harmonics is for me a very tempting experiment.
Patrick
Hey I think that's me Patrick! So thanks a lot for the ad. Btw, it's ok to quote my forum name
stevejones recently got a set as you specified but I don't have any more of the 0.8mA matched pairs. I hate to break up the closely matched ones though.
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright 1999-2017 diyAudio
