F5 power amplifier
F5 power amplifier
Old 18th August 2010, 05:14 PM   #8671
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
Default Current limiting or no?
OK, so I have most of my F5 parts now, and I'm wondering, in light of what some have said about audible gains, whether or not to remove the current limiting part of the circuit.
I know it has been done several times with success, and apart from some reports that there is a marked improvement in the sound, (post 2814) all I know is that there will be a longer bias adjusting procedure and that I must make doubly sure that my heat sinks are adequate and that I don't short my outputs for so much as a split second.
Should I built the full circuit first and then cut the traces later, build the full circuit and be happy, or go straight for the purer/simpler circuit from the off?
So far, I have this: F5 without Current limiting/Thermistors
Unsubstantiated opinions welcome!
Lucas
Old 18th August 2010, 05:18 PM   #8672
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
ehh, I thought all the bias issues only related to that thermistor thing, and that the thermistor it could still be used and work well, without the transistor limitor
anyway, Nelson's own F5 beats them all, with thermitor and limitor, as pr manual
but probably a balance act with special care to adjustments and parts
I suspect its also a matter how its put in use, with regards to speaker load, SPL, etc
Nelson suggest easy going speaker, and it is probably also tested that way, when winning the prices
others here may use totally different and tougher speakers, and that may change everything
you may have to look a summed amplification gain through your whole setup
sometimes we know very little, and sometimes we know too much
Old 18th August 2010, 05:22 PM   #8673
I'm sure you're right. I got this schematic from somewhere in this thread some time ago, where someone had clearly removed both.
Perhaps the thermistors should stay. I don't know really, so I ask...
Lucas
Old 18th August 2010, 05:29 PM   #8674
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
You can do quite a few variations on this sort of circuit,
and each will bring something different to the table. No
reason you can't try as many as you like (easy enough!)
and take a listen, I do it all the time.
Old 18th August 2010, 05:40 PM   #8675
Well, I think I will do the circuit as you settled on it Nelson. I can then evaluate it for myself instead of taking other's word for it.....if they knew so much, I guess they would have designed it in the first place and not you.
Thanks Admiral! My mind is made up. You the man!
OT: I've been meaning to ask you your thoughts on the DCB1. Have you tried it yet?
Lucas
Old 18th August 2010, 05:55 PM   #8676
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Hi Lucas
Its much easier to snip the legs of some of the parts after you have assembled the amp, rather than carefully disassembling the amp at a later date...I guess that will happen regardless!
That's the most sensible thing I have said all day...
Old 18th August 2010, 06:37 PM   #8677
R.I.P.
post2819 offers an explanation and a solution to the current limiter being audible.
regards Andrew T.
Old 18th August 2010, 06:52 PM   #8678
chchyong89 is offline chchyong89  Malaysia
Send a message via MSN to chchyong89
i have a question. what condition will make R11 and R22 on fire? I try to adjust the pot again and again, but it still on fire
Old 18th August 2010, 07:56 PM   #8679
Shame it's all above my head Andrew. You might as well be talking Saturday night Glaswegian
Lucas
Old 18th August 2010, 08:33 PM   #8680
Melon Head is offline Melon Head  Australia
Banned
Build one channel with current limiter and one channel without current limiter.
Have a listen to both. If the circuit without current limiter sounds better, then remove the current limiter from the other channel.
If you can't tell the difference, then you may as well add it to the other channel.
Don't be afraid to experiment.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
