#8661 |
Lightning In A Bottle
Nope, not at all...and these have been verified as similar to his by sangram. All I'm trying to point out is the interpretation of what you are reading from the F5 output...at first glance it will tell us the readings come from the 2 feedback loops and the Source Rs but from the measurement values you called out other paralleled loops are also involved.
Btw, have you powered up your creation and listened?
Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html |
#8662 |
Oh fine. I might be able to borrow a scope as I would like to make sure everything is OK. The amp sounds good, apart from a slight hum.
Thanks for asking the questions
#8663 |
Hum would be due to a ground loop problem, how have you connected the input, output and power grounds? My amp is dead silent, probably the quietest I've ever built.
#8664 |
Hi Richard. I know it's a pain, but it's well worth trying to eliminate the possibility of an earth loop before you delve deep into F5 component failure analysis. They are some right bloody gremlins to track down sometimes, because they sometimes occur due to cables that you can't practically remove from the setup, like your pre to power RCAs for example. That's why I sent you that link to the page that discusses directionality of earthing, and how the flow direction must be forced back away from the pre-amps and sources by way of cable size differences. The biggest mistake with earthing is, noting that all of the earth points link up to the same destination/source, deciding to not to send separate cables for each earth point and instead making a string that catches each one. I made that mistake, and I'm sure it's quite common to do so, but it causes hum, so check that you haven't done that anywhere.
Lucas |
#8665 |
To paraphrase LucasA;
Star ground > parallel > series grounding techniques. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#8666 | |
But yeah, Star grounding with tiny cables for signal earth to a signal sub-star linking with larger cables to the master star on the case body with power earths and huge cable to link the master star to the power inlet earth, keeps the flow in the right direction. Make sure that the signal earths are not directly attached to the case body.
Lucas |
#8667 |
Hello everyone here and hello papa! This is my first post in this thread, however I've been a reader of this thread for quite some months and have started to think of f5 as my next project. I have a question about the power mosfets.
Can Laterals be used in place of those IRF devices without problem? Has anyone here tried something alike? I actually have some spare hitachi devices resting, so I thought I'd better put them to work. so... Thanks in advance.
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#8668 |
Laterals swapped for the F5's Verticals are discussed a few times in this thread.
#8669 |
I see... I must have missed some pages... my bad
Thanks... I'll try to find the posts.
#8670 |
Laterals
yeah, I was daft enough to actually buy a bunch of selected Renesas no good low conducting, they say so I decided to use for other amp(AB) But now I have decided to try them as double pairs in F5 I dont care if it wont be the best ever I think part of the trick is to beat them hard with aggressive bias and that means huge heatsinks, which I happen to have
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
