Old 24th May 2008, 01:12 AM   #851
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
Default More on the F5...
http://6moons.com/audioreviews/firstwatt7/f5_2.html
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
Old 24th May 2008, 02:45 AM   #852
fab is offline fab  Canada
fab's Avatar
Default Re: Re: Profet like amp
Originally posted by jackinnj
I have been able to run the lateral version at ~20W, but can't get the distortion below 0.3% -- it is pretty much "untweaked", however.....
What power supply voltage and how many output pairs?
I got about same THD even after tried to tweak it but I had only one output pair...but the max voltage swing was limited under 8 ohms load
Old 24th May 2008, 03:10 AM   #853
The one and only
Nelson Pass's Avatar
One thing you can do is to reduce the gain of the amp. 15 dB of
gain is plenty, and compared to 20 dB, that will reduce your
distortion by about half.
Old 24th May 2008, 09:36 AM   #854
Skorpio is offline Skorpio  Denmark
I have found at suiteable heatsink for each channel and the distance between each output MOS-FET will be 20cm. This gives some questions about the physical layout:
1. Do I mount each JFET close to the MOSFET and run wires to the other half?
2. Do I mount the input JFETs close to each other and run wires to the MOSFETs?
a) Do I let each half have its own feedback loop before running the output to output terminal, where the two half meet?
b) Do I connect the drains of the output MOSFET and run this point to the output terminal. And from here take feedback back to input?
My own idea is to use 1b, but is that the best way?
The principle question is where to have short wires and where to run longer...
Old 24th May 2008, 10:23 AM   #855
Goffe is offline Goffe  Sweden
Default beginner's pcb
This is my second design, if you find any error please advise me or to make the design better. I will release etch layout later if the design is ok. Size is 7,5x5cm
I don't think the tracks can handle 10A current...etc.
Thanks Nelson
Old 24th May 2008, 10:30 AM   #856
...now you got 3D
Old 24th May 2008, 12:54 PM   #857
jackinnj's Avatar
Originally posted by jacco vermeulen
Carol-Ex,
care to give a recap ? (titter revisited)
The gate resistors value was ?
And the Ap-plot is for both N- and P-channel Fairchilds, right ?
I got tired of Carol, but am thinking to use one of the pictures from Janneman's visit to the lovely women of SEAS. The current av is a solar flare.
The plot which I published depicted the P-channel replaced. I then replaced the N-channel as well and the result is the same -- still peaks at around 500kHz (but I can't do a screenshot with my HP3577.)
I am using 47R gatestoppers.
This is the product of my other labors:
Old 24th May 2008, 05:49 PM   #858
Hi Goffe,
Perhaps you could seperate R9 / R10 and move the Q1 and Q2 together (with a "clip")
It wouldn't be difficult to seperate R9 & R10 to fit a bipass cap from V+ to V-, as I have often found this to be beneficial to the sound.
I'd perhaps move the V+ (& V-) terminals(?) to the edge of the pcb, ie, between TH!- Q3 (TH2- Q4) where the round pads are now, and reroute the tracks from R13,21,19 (14, 22, 20) under R11 (12).
Suggest a bit more room around the IN & GND pads, and possibly add a second centre pad for Q5,6 to aid different "pin-outs".
As is often done on NP's designs, adding Cmultipliers to the power rails, near to the main o/p Fets - good results, generally.
... jh
Old 24th May 2008, 06:25 PM   #859
I would suggest that people doing F5 pcbs look at Nelson's layout in the pictures of the most recent 6moons article. The location of the "current" feedback resistors are close to the jfet input stage. I believe he is minimizing the trace length on the voltage sensing side of the resistors which are more sensitive to noise than the output stage end of the resistors.
Old 24th May 2008, 06:37 PM   #860
Originally posted by jameshillj
Hi Goffe,
I still learning Thanks
I need to see the 6moons article and get back to work
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.20811 seconds (69.25% PHP - 30.75% MySQL) with 11 queries
