Old 25th July 2010, 01:25 PM   #8481
Marra is offline Marra  United Kingdom
Schottky's from Farnell---8657173
Old 25th July 2010, 01:47 PM   #8482
Originally Posted by LucasAdamson View Post
Can anybody recommend a good, fast diode that is relatively cheap for using with an F5? I have some MUR3060s in my Digikey shopping trolley right now, but at $40 for eight, I'd prefer to find something a bit cheaper if possible. I am using 8 because I'd rather it was 2x mono from the secondaries onwards.
Also, what does Nelson use in his commercial model?
I use 8XMUR860GOS-ND in my F4, it should be good for F5 too.
Old 25th July 2010, 10:13 PM   #8483
LucasAdamson's Avatar
Now, I do have 8x MUR860s leftover from my Peter Daniel's Gainclone kit, but I am sure I've read that they're not much good for high current Class A amps as it's not rated high enough. Any opinions on that?
Lucas
Old 25th July 2010, 10:21 PM   #8484
I believe Peter stated as much over on his GB thread for the F-5. I used his recommended MUR 3060 devices. Others I know used HEXFRED block devices, WAY less soldering and fitment, thats for sure. That said, thesse MUR 3060 are tuff.
Russellc
Old 25th July 2010, 10:23 PM   #8485
Originally Posted by juma View Post
Rusellc,
there's nothing really wrong with your amp as it is - you did a nice job
It's just that using the shorter leads gives you the feeling that you did everything right
Much appreciated. But if they need to be shortened to decrease power supply impedance......maybe I should. Right now I dont seem to be able to power down!
Russellc
Old 26th July 2010, 08:10 AM   #8486
I used this Vishay in my F5
Digi-Key - 30EPH03PBF-ND (Manufacturer - 30EPH03PBF)
but it's not available right now.
Old 26th July 2010, 06:04 PM   #8487
Send a message via MSN to chchyong89
Can the fast diode have a better in term of sound quality? if yes i gonna change my Square Bridge diode.
Old 26th July 2010, 06:24 PM   #8488
jackinnj's Avatar
Diodes seem to be more problematic when you're using a transformer with high leakage inductance -- in this case, the junction capacitance of the diode and the leakage inductance form a resonant circuit -- and the diode rings -- the energy can be rectified by the various PN junctions in the amplifier and causes "unexplained, explained offsets".
Old 26th July 2010, 09:05 PM   #8489
umut1001's Avatar
I use 600va 4x18v toroidal transformer for stereo F5.In the past i used chinese made metal 35A bridge diode.And recently i found a higher quality IRF brand 40A bridge diode.There has been a voltage increase about 1.5volts then.I thought that it will be better to use an ultra fast diode but now i am confused(I also do not know how to connect 3 leg ultra fast diode.I want to seperate the stereo channels.Some of the diodes are common cathode and some of them are common cathode.Should i use them as complemantaries?)
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components
Old 27th July 2010, 04:13 AM   #8490
EUVL is offline EUVL  Europe
To confuse you even further :
http://www.hagtech.com/pdf/snubber.pdf
Patrick
PS.... BTW BYW99W-200 is obsolete. There is a more up to date part STTH6002C.
STMicroelectronics | High efficiency ultrafast diode - STTH6002C
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.19553 seconds (62.15% PHP - 37.85% MySQL) with 11 queries
