F5 power amplifier
F5 power amplifier
Old 21st May 2008, 01:24 AM   #821
fab is offline fab  Canada
fab's Avatar
Default Re: Re: PROFET Question
Originally posted by Nelson Pass
That appears to be consistent with "Chuck" Hansen's review of the
Profet in AX magazine, in which he measured a 6.8 ohm output
impedance. That doesn't mean that the amp sounds bad, but it
tends to limit its application.
So 6.8 ohms output impedance is far away than a R2R design thus a lot of power "lost" for a common source output stage...
Also I could not get THD (1KHz) lower than 0.6% at 16Vac with 23Vdc power supply (at higher level it clipped but with a gradual rounded shape instead of flat) ... THD at low level was about 0.2%....is it consistent with Profet amp spec?
Unless using a hig hvoltage supply, I guess such a power amp design (Profet or F5) is not for Laterals... I have a few that I wanted to use...
Old 21st May 2008, 02:29 AM   #822
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
Offhand, the numbers look consistent with Hansen's measurements
of the Profet.
Perhaps you are being harsh in judging your amplifier. Those
numbers do not necessarily mean that it sounds bad, nor does it
mean that you are done tweaking this until it sounds better yet.
Old 21st May 2008, 10:47 AM   #823
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Default Re: Re: Re: PROFET Question
Don't give up so soon.
1. How many laterals do you have? Parallel them. You will not need source resistors even if you parallel them, laterals have positive tempco already at very low currents (if I recall correctly, these have zero tempco at around 100mA.)
2. Q9 and Q10 are not really needed at this low supply voltage. Btw, with the biasing resis-tor values shown in your scematic, they allow for only 2.5-3V over the JFets. This is low for high input signal levels.
3. I am puzzled about the values for P1 and P2. The laterals need around 1.5 - 2V G-S for 0.6A bias. That means only 2mA through the JFets??
I think that your main problem is the low transconductance of the laterals and the low Gate Source voltage needed to "open" them. Both result in a much lower OLG than the F5.
I suggest you a workaround according to this schematic:
Current sources with parallel resistors instead drain resistors P1/P2. This allows to increase OLG despite low voltage drop.
I have used your cascode transistors for that
Use the F5 feedback arrangement, it allows for lower degeneration despite same source R.
The resistor values are starting values. No sim values! You have to tweak them, maybe massively.
Success, Tino
Old 21st May 2008, 04:56 PM   #824
stefanobilliani is offline stefanobilliani  Italy
I have some questions before starting the building :
1) does F5 need a preamp?
2) may I decrease R11 and R12 slightly to 0,5 ohm?
3) If I use Fostex drivers as FE206 , are applyable the same tecniques described in " current source amplification " when my needs comes down to equalization? For Both F5 and F3 ?
edit: 4) Are ok 2sj109 here ?
thanks
Old 21st May 2008, 06:20 PM   #825
The one and only
F5 power amplifier
No, it has enough gain depending on the sources
You mean increase? Yes, no problem.
The F3 and F5 are not current sources - the equalization
technique for current source amps will not work.
Yes.
Old 21st May 2008, 07:15 PM   #826
thanks ; yes I meant increase R11 and R12 .
Thats ok , so I am nearly ready , just need to find the thermistor ...
Old 21st May 2008, 07:32 PM   #827
apassgear is offline apassgear  Mexico
apassgear's Avatar
Yes, I was wondering which thermistor are guys buying. I was looking for one whith a tab and hole, but can't find any on that package.
Old 21st May 2008, 07:52 PM   #828
audiorasp is offline audiorasp
F5 power amplifier
Default thermistor
I'm going to try some Cantherm thermistors from digiKey, part # 317-1360-nd. My plan is to drill a small hole in the heatsink next to the mosfet and stick the head of the thermistor in it, insulate the leads and run them back to whatever pcb I decide to make for this amp.
George
Old 21st May 2008, 08:19 PM   #829
apassgear's Avatar
That's a good solution, hole in the heatsink and silicone grease
Old 21st May 2008, 08:26 PM   #830
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
any sort of clamp is good enough , too .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
