F5 power amplifier
F5 power amplifier
Old 23rd June 2010, 03:10 PM   #8191
udailey is offline udailey  United States
Passive Aggressive
F5 power amplifier
Originally Posted by acold7dusta View Post
amp's running much more stable (cooler and less noise), and sounds much more "relaxed", with an increase of upper midbass...interesting
What did you do to get this gain in sound quality and stability?
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 23rd June 2010, 06:47 PM   #8192
serious_lee is offline serious_lee
I finally got my FETs in and I am wondering how you guys go about matching (or if you bother). I have 20 of each JFETs and 6 of each MOSFET. I read somewhere that there were many more needed (1000 comes to mind) to get a good match. Please reply back with methods, circuits, links etc. so that I can compare what I've read to experienced guys. There's a lot of information out there for a newbie.
Thanks,
Everett
Old 23rd June 2010, 07:11 PM   #8193
Electrolastic is offline Electrolastic  United States
I am building a F5. However, I have problem with thermal drift. I use 5K NTC thermistors. Output DC swings up to 100mV and idle current swings up and down too.
I attach the thermistors to the power MOSFET with glue. What is the proper way to mount/attach the thermistors? Would some one help. Thanks.
Old 23rd June 2010, 07:34 PM   #8194
Bidoux is offline Bidoux  France
I have to apologize, I didn't read the whole thread, but it is quite obvious, seeing it's lenght. So maybe my question has already been asked.
Here, on figure 15 we can see an amp that looks like a F5 with bipolar instead of fets. The author says it is a design to avoid.
Is the F5 so much different that the topology is no longer a problem ?
Old 23rd June 2010, 07:44 PM   #8195
gaborbela is offline gaborbela  Canada
Hello
Please use the melting type of glue . That has great conductivity .
In case if the mosfet and the thermistor has different temperature .
Greeting
Old 23rd June 2010, 07:50 PM   #8196
acold7dusta is offline acold7dusta  United States
acold7dusta's Avatar
It was a matter of not sounding right, vs. sounding normal. I removed my zobel network (cap & R in series), and swapped out my high capacitance cat 5 speaker cables, with normal 12ga wire, and tweaked the bias. I'm now at .685V on the left with <1mV dc offset, and .687V on the right with ~1mV dc.
The right channel still gets very hot after about 2 hours, so i definitely need to give it more air to breathe (open rack is on the left of my speaker)
Bluesound Node 2>PS Audio Perfectwave DAC>Marantz PM-15S1>Seas Thor (Small)
Modified Squeezebox Touch>Millet Max>Grado SR60e
Old 23rd June 2010, 07:55 PM   #8197
Originally Posted by Nelson Pass View Post
Some capacitance across the 100 ohm feedback resistors will
stabilize that. Start with .001 uF and work up to .01uF.
Thanks, what kind of effect will I look for on a scope? still new to scopes
Old 24th June 2010, 10:48 AM   #8198
Marra is offline Marra  United Kingdom
F5 power amplifier
Has anyone used transformers from Toroidy.pl. I seem to remember that someone said they were going to try them and post results but I havent come across any more posts. I still have another 100 pages to read so maybe I havent found his results yet.
Old 24th June 2010, 11:14 AM   #8199
there's one on page 696, from doing a simple search
Old 24th June 2010, 12:36 PM   #8200
F5 power amplifier
Thanks for the pointer
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
