F5 power amplifier
F5 power amplifier
Old 22nd June 2010, 07:48 AM   #8181
osscar is offline osscar  Latvia
osscar's Avatar
thanks for the advice Master! This definitely helps.
My DIY : http://www.tutribi.net
Old 23rd June 2010, 12:16 AM   #8182
acold7dusta is offline acold7dusta  United States
acold7dusta's Avatar
Originally Posted by acold7dusta View Post
has anyone built zobel networks for their F5, or is it not necessary for this topology? I'm running higher capacitance CAT5 cables (10ft)
bump
Squeezebox Touch>Coax>MH Dac 25.2>Marantz PM-15S1>Seas Thor (Small)/Beyerdynamic DT770
Old 23rd June 2010, 12:42 AM   #8183
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
Output is stable
But you may have to be careful with source and interconnects
sometimes we know very little, and sometimes we know too much
Old 23rd June 2010, 12:59 AM   #8184
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
bump
If this cable does not work, try an ordinary one instead of adding a zobel.
Old 23rd June 2010, 01:09 AM   #8185
carlomar is offline carlomar  Portugal
carlomar's Avatar
bump
I try a high capacitance speaker cable and fuse blow up.
Old 23rd June 2010, 01:16 AM   #8186
thanks for the replies, I'll try ordinary 12ga and see if runs any cooler (couldn't hold my hand to 5 seconds, zobel wasn't helping)
without load, i can hold it comfortable for over 20 seconds
Old 23rd June 2010, 01:36 AM   #8187
F5 power amplifier
quote from F5 manual
A caveat is in order here – this is a very wide band amplifier with a high input
impedance. In order to prevent the output voltage from bleeding back to the
input at very high frequencies (thus making a fine power oscillator), keep the
input and output cables separate, and don’t externally connect the speaker
ground to the input ground. Good ground shielding on the input cables is
important, and caution is called for in using Litz and other specially low
inductance / high capacitance cables. I have not seen a specific example of a
problem, but historically it is to be expected when an amplifier’s bandwidth
exceeds 200 KHz. If the amp makes funny noises, runs extra hot, or blows
fuses, this might be an indicator of such an issue.
quote from above
I suppose speaker ground(power supply) and input ground(chassis) is seperated by thermistor
Old 23rd June 2010, 02:41 AM   #8188
quote from above
I've read that, but after all the countless hours I put into those cables I just REALLY wanted to make them work...
Old 23rd June 2010, 02:55 AM   #8189
amp's running much more stable (cooler and less noise), and sounds much more "relaxed", with an increase of upper midbass...interesting
Old 23rd June 2010, 04:59 AM   #8190
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
Some capacitance across the 100 ohm feedback resistors will
stabilize that. Start with .001 uF and work up to .01uF.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright ©1999-2017 diyAudio
