F5 power amplifier
F5 power amplifier
Old 21st June 2010, 04:59 PM   #8171
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
Thanks for all this information, it is very helpful, also to choose the correct heathsinks.
Yes, I've read the manual. It is very complete, compact and easy readable.
Thanks, Nelson!
Still, I need to simulate "my" psu, as I dont have a 18VAC trannie, but 20V.
Too high?
Do I have to waste some watts in higher R value in the CRC filtering?
Or do I better a CRCRC filtering, with this trannie?
Or do I wait till my money allows me to buy a 18V trannie?
Franz
Old 21st June 2010, 05:16 PM   #8172
Blues is offline Blues  United States
Blues's Avatar
The Conrad HS, as pictured with the dimensions, can actually dissipate 100W quite nicely...that has been used with Aleph 3/30 before...so the 65W/ch F5 will run cooler on this HS.
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 21st June 2010, 05:18 PM   #8173
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Thanks Blues
Old 21st June 2010, 05:46 PM   #8174
osscar is offline osscar  Latvia
osscar's Avatar
When I take my F5 (with 230V mains rating) to the UK - then the transformer started to hum. In the UK a real voltage in mains network was approximately 245V. In addition, the bias rises because the PSU Voltage increase of a few V. Perhaps it also depends on the quality of the transformer.
Now I am back from a few month business trip in my country - and transformer is silent. Here in mains - approx. 220V.
My DIY so far: two Leach amps, Pass AB100, Pass F5, B1 buffer, Hiraga le monstre, two LM3875, LM1875, OPA549, 6C33C SE, GU32 PP, 6p3c-e PP, Marsh headphone amp.Phono - OBH-8se, Pacific RIAA, inDiscreet Phono, Whammy headphone amp.
Old 21st June 2010, 06:25 PM   #8175
Mooly's Avatar
F5 power amplifier
Have a read at this for noisy toroids,
Mains DC and Transformers
Old 21st June 2010, 06:31 PM   #8176
osscar's Avatar
Tnx, i will read .I just shared my experience with 230V rated trafo.
Old 21st June 2010, 07:18 PM   #8177
Tripmaster's Avatar
I think Peranders has something for this. I remember reading about this a while back.
sjostromaudio.com - DCT01 The DC trap, high-end style
Old 21st June 2010, 09:33 PM   #8178
udailey is offline udailey  United States
Passive Aggressive
F5 power amplifier
Originally Posted by bobodioulasso View Post
Most of the ever asked questions are answered in the pdf manual . From noise figures to heatsinks size. And a lot more. Reading it deeply is very informative.
True. It really is a fantastic article. I read it again a few days ago and learned more. Stuff I could not have understood the time I read it before this was now clear. There is still lots I dont understand in it and would be really nice if each paragraph was broken down yet further but man it sure is a nice article and I really appreciate the Pass Library.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 21st June 2010, 10:42 PM   #8179
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Thanks, Nelson!
Too high?
Franz
I would go with the 20v transfo. You will get 27 to 28 volts dc which should not kill the jfets.
If you are afraid of these few more volts you can cascode the jfets.( see Cviller blog) or even use an active filter which can drop out about 4 volts.( see zen v9 article)
Old 21st June 2010, 11:21 PM   #8180
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
Throw another thermistor in series on the AC line when it hums.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
