F5 power amplifier
F5 power amplifier
Old 16th June 2010, 11:19 PM   #8101
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
F5 power amplifier
Originally Posted by a.wayne View Post
No such thread found by search james and since we are discussing the F5 please go ahead and give your opinion on the different caps and there associated sound. here!
f5-listening-impressions-discussion
F5 Listening Impressions & Discussion
Currently listening to F4 or F6/w curve matched SemiSouth outputs
Old 16th June 2010, 11:42 PM   #8102
jameshillj is offline jameshillj  Australia
Thanks ichiban, that's the one - full of good info.
The capacitor thread is called "best electrolytic capacitors" and last post was may 20th and there was another one talking specifically about 10,000uF caps but can't find it myself, sorry - perhaps someone can assist?
Old 17th June 2010, 02:46 AM   #8103
serious_lee is offline serious_lee
Default How does this look for part placement?
I plan on mounting a third sink for a back plate, but you get the general idea. I was thinking the thick plate in the front would be a nice mount for the heavy toroid.
Thanks,
Everett
Old 17th June 2010, 08:23 AM   #8104
R.I.P.
I wonder if the smoothing caps will run cooler if the PSU is turned upside down to place the caps in contact with the perforated bottom plate?
regards Andrew T.
Old 17th June 2010, 02:06 PM   #8105
Are they really at risk for running that hot? I plan on using 50V caps in case that matters.
Old 17th June 2010, 02:23 PM   #8106
labjr is offline labjr  United States
It would probably stop the heat from rising and make the caps run hotter.
Old 17th June 2010, 04:37 PM   #8107
bear is offline bear
expert in tautology
bear's Avatar
F5 power amplifier
assuming that the top plate is not solid and there is a vent somewhere the convection upwards from the bottom though the holes will not be insignificant... I doubt that mounting the caps upside down would have any benefit compared to the work involved in doing it.
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 17th June 2010, 05:14 PM   #8108
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
My F5 caps are not heating.
Old 17th June 2010, 05:26 PM   #8109
Renron is offline Renron  United States
Renron's Avatar
If the caps are getting hot from passing energy, maybe the voltage rating is too small
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 17th June 2010, 05:33 PM   #8110
a.wayne is offline a.wayne  United States
Sin Bin
I was talking about this one
Originally Posted by jameshillj View Post
Yeah, Bear, I'm a bit off topic about that - sorry.
In a similar way, jackies & umut, the thread of "the best 10,000uF capacitor ..." has good discussion of the properties of various caps - a whole lot of good info there, better than I can do.
OK, i see which thread !
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
