F5 power amplifier - Page 808 - diyAudio
Old 10th June 2010, 06:24 PM   #8071
expert in tautology
bear's Avatar
Beware, the coefficient of expansion for copper and aluminum are different.
This thing may get hot enough to cause bending due to this...
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 11th June 2010, 03:04 PM   #8072
Is this the one you were talking about Andrew?
Natural convection heat sink
Old 13th June 2010, 12:53 PM   #8073
Here are some images from the above tool. What a great piece of software for a diy guy! The heat layouts are based on the cviller board spacing and a generic 16x20mm footprint dissipating 30W.
Old 14th June 2010, 09:38 AM   #8074
Yes, that is familiar.
adjust until the contact interface uner the device/s is at it's coolest
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th June 2010, 12:24 PM   #8075
Marra is offline Marra  United Kingdom
Would there be any gain to using separate supplies per channel i.e +- 68000uf or a single supply of +- 136000uf with the anti ripple resistors? between the caps
Old 15th June 2010, 01:20 PM   #8076
expert in tautology
bear's Avatar
With a double supply ("monobloc" or "dual mono") the inter channel isolation is 100%.
With a single supply ("stereo") there is some interchannel "cross-talk" via the supply.
We're assuming in the second case there are two, not one power transformers??
In practice it may not make a real world difference to your ears - or it might.
Certainly opens up different chassis variations.
_-_-bear
_-_-bear
Old 15th June 2010, 01:56 PM   #8077
umut1001's Avatar
Hi.I have 600va transformer and it has 4x18v output.And i use them seperately.2x18v for one channel and other 2x18v for another channel.Is not it enough to deny crosstalking?I think it is not same as two transformer?Does it make big difference?
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components
Old 15th June 2010, 02:15 PM   #8078
expert in tautology
bear's Avatar
Should be fine umut... especially for a Class A design where the current draw is fairly constant...
_-_-bear
Old 15th June 2010, 02:37 PM   #8079
the core, the primary and the chassis are common between the two channels. That can never have as good separation as two monoblocks.
But, 4 isolated secondaries is a very big improvement on a shared set of secondaries.
regards Andrew T.
Old 15th June 2010, 02:49 PM   #8080
Thanks for the response Bear. Yes I was intending to use two transformers in the one chassis with 4 bridge rectifiers. What would be the size of trannies to use as Nelson I understand uses a 300VA in the Firstwatt F5? Would two 300VA's be overkill?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
